H22 type-R Motor valve train question
Old Mar 4, 2004 | 01:58 AM
austrian type-R's Avatar
Default H22 type-R Motor valve train question
hi!
I need better valves for the H22 type-R engine. What brand can you guys recommend. I also need new rocker arms, seems the oem ones are grinded. Should I get oem nes or are there aftermarket ones available.
thanks
Old Mar 4, 2004 | 02:42 AM
ATS*Mark's Avatar
OG triple OG
Default Re: H22 type-R Motor valve train question (austrian type-R)
you mean the type S.....
get jun
Old Mar 4, 2004 | 02:54 AM
Default Re: H22 type-R Motor valve train question (Hella_JDM)
no, I mean type-R engine. I am from europe, Accord type-R
Old Mar 4, 2004 | 03:33 AM
ATS*Mark's Avatar
OG triple OG
sorry i was thinking prelude , my bad......
Old Mar 4, 2004 | 10:46 AM
@ries's Avatar
You should post this in the Prelude forum since most of the questions involve H22A's over there.
EDIT: This was originally in the Type-R forum.
Modified by emoBB1 at 1:44 PM 3/4/2004
Old Mar 4, 2004 | 07:21 PM
satan_srv's Avatar
Default Re: H22 type-R Motor valve train question (emoBB1)
And ATR engine is just a type-S head...
Anyways stock OEM valves work fine...what's 'better' in terms of valves that you are looking for.
If your rocker arms are worn you might want to figure out why they are all worn out before you just replace them
Old Mar 4, 2004 | 08:20 PM
Default Re: H22 type-R Motor valve train question (satan_srv)
I need flat valves to get out mor compression
Old Mar 5, 2004 | 07:37 AM
JUNPWRD's Avatar
Try these for a little higher compression. I believe Skunk2 also makes some of these.
http://www.jhpusa.com/catalog/...d=196
gnxpro24
Jul 15, 2014 08:02 PM
1991_crxsi
Jan 24, 2014 02:30 PM
Conflicted
Mar 7, 2010 05:21 PM
SiR-T
13
Aug 8, 2006 02:06 PM
4drsedaneg
Apr 12, 2005 12:09 PM
