F#@$# squek in dash.. anybody know how to pull apart dash on 6th gen ? Opinions?
Old Mar 3, 2004 | 09:12 PM
Kavehman's Avatar
Default F#@$# squek in dash.. anybody know how to pull apart dash on 6th gen ? Opinions?
Ok I have the freakin squek which is really pissing me off, its not a dash squek it sounds like something is rubbing against something else.
Ok the sound comes whenever I start the car along with a clunk from that same area, it also squeks when i turn the car off, it seems to happen when i give the car gas or when the engine moves, or flexes. It does not happen when i hit bumps, only when i give it some gas or even push the clutch in. Before I used to be able to make the squek intensify in pitch by pressing the throttle gently. And no it doesn't squek when the car is off and i play with the throttle, SO i think its something attached to the firewall.
Its coming from the passenger side dash area. Does anyone have any pictures or know any links or anything on how to pull apart the lower or upper dash.
Any opinions or advce would be appreciated, this noise is majorly annoying
Old Mar 3, 2004 | 10:57 PM
Vtexivic's Avatar
Default Re: F#@$# squek in dash.. anybody know how to pull apart dash on 6th gen ? Opinions? (Kavehman)
thats what i was going to say
Old Mar 4, 2004 | 08:26 PM
Kavehman's Avatar
anybody ?
it only does it when you push the throttle and cars in gear ???
Old Mar 4, 2004 | 10:16 PM
Bishop Don Shizzle's Avatar
Oh yeah I forgot I can edit my own title! Yay!
Good luck trying to pull it apart. You're going to have to pretty much take everything off including the sectiosn around/below the radio. It's a bitch but once you start unscrewing things they just start to come off. Should take about half an hour max to get it all off.
Honestly I'd say don't do it. I've been noticing a lot of squeaks and stuff in my car (6th gen) but I just attribute it to wear and tear and not let it bother me. <shrug> Might be different for you though. Good luck.
Old Mar 4, 2004 | 11:18 PM
pho iz good's Avatar
Party Pooper
me too, Im hearing squeeky noise inside the dash passenger side and the door behind the driver side. I heard these squishing noise whenever I brake or accelerate. At first I thought it was the coilovers but it cant be..the sound IS NOT coming from the strut tower area. the sounds is inside the car.
Old Mar 5, 2004 | 10:42 AM
jweller's Avatar
you don't wanna pull the dash
http://www.honduh.com/showthre...+heat
have you checked your motor mounts? especially the rear one?
Old Mar 5, 2004 | 10:58 AM
vc's Avatar
vc
Default Re: F#@$# squek in dash.. anybody know how to pull apart dash on 6th gen ? Opinions? (jweller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller &raquo;</TD></TR><TR><TD CLASS="quote">you don't wanna pull the dash</TD></TR></TABLE>
amen to that.
Old Mar 5, 2004 | 11:06 AM
iam7head's Avatar
Default Re: F#@$# squek in dash.. anybody know how to pull apart dash on 6th gen ? Opinions? (sh0rti)
mine do the samething...
with much less miles on her too
Old Mar 5, 2004 | 11:08 AM
Crono139's Avatar
I'm thinking it's something in the engine bay rubbing against the firewall. Probabaly below the fuse box.
Old Mar 5, 2004 | 02:10 PM
Kavehman's Avatar
im gonna tackle the problem this sunday, hopefully it is something in the engine bay, if i do have to pull apart the dash ill take some pics and post em up.
Thanks for the replys
stampern22
47
Jan 30, 2019 01:24 PM
philosofy1
Jan 8, 2008 02:16 AM
m1ndless
Sep 10, 2007 05:05 PM
darkd1gt
Jul 15, 2007 11:37 AM
tony007
Apr 27, 2005 10:37 AM
