gsr w/b16 tranny??
Old Mar 3, 2004 | 08:21 PM
megotvtec's Avatar
Default gsr w/b16 tranny??
ive noticed alot of gsr's with b16 trannies, what r the advantages of of the b16 tranny on a gsr? how much would that help your 1/4mile???
Old Mar 3, 2004 | 11:45 PM
inzaneN1's Avatar
From: INZANE FOR PRESIDENT 2008 .., las vegas nv, U.S.of.A
Default Re: gsr w/b16 tranny?? (megotvtec)
they have pretty much same gear ratio as type r's minus the lsd.
Old Mar 4, 2004 | 02:23 AM
b00sted4dr's Avatar
Default Re: gsr w/b16 tranny?? (inzane)
Advantage would be shorter gearing.
Old Mar 4, 2004 | 02:15 PM
megotvtec's Avatar
Default Re: gsr w/b16 tranny?? (96gsr4dr)
i know they have shorter gear ratio, but would that make it better for the 1/4mile?? if it depends on your setup then use my setup as an example. would you want shorter gearing w/n2o?
Old Mar 4, 2004 | 02:30 PM
integraGSR1's Avatar
with shorter gearing, you will acclerate quicker. the idea drag racing gearing, for me at least, is right as you pass the finish line for your 1/4 mile times, you hit redline in your higest gear. and becasue of the shorter gears, you will wind up your motor quicker, therefore making your car quicker.
Old Mar 9, 2004 | 01:56 PM
megotvtec's Avatar
Default Re: (integraGSR1)
well in that case i would want longer gearing cause when i cross the finish line im in 4th for about a full sec but with shorter gears i would be in fourth for a while
sleekcesar
Transmission & Drivetrain
10
Nov 18, 2009 10:23 PM
jdm_integsr
Jun 8, 2006 10:55 AM
swaytec360
Jul 12, 2005 08:11 PM
Passaudi1.8t
Jan 21, 2003 12:04 PM
