which intake?
Old Mar 3, 2004 | 07:39 PM
boost_addict's Avatar
Default which intake?
i wanna run a comptech icebox intake on my car. for which car should i order it for, car is 00 Si with b20/b16 head with JG intake mani. help suggestions would be geatly appreciated. thanx
Old Mar 3, 2004 | 07:44 PM
Kendall's Avatar
for the Comptech, but I'm not sure of fitment for the Si's. If they make one for the Si, then it should fit regardless of which block you are using, it will sit higher and might require some finesse to mount.
Old Mar 3, 2004 | 07:53 PM
the problem i'm having is the placement of the throttle body with the jg manifold. the stock Si one sits higher than the jg and the stock gsr one sits lower than the jg. i guess i'm sorta stuck in between
Old Mar 3, 2004 | 07:55 PM
Kendall's Avatar
But won't the extra deck height of the B20 help to offset that difference? You should be somewhere close to the stock Si height.
Old Mar 4, 2004 | 08:02 AM
anyone with this setup have any sugestions
wasanissanFL
Nov 13, 2015 09:28 PM
Austin
Nov 29, 2003 06:08 PM
speedevo
Sep 10, 2002 05:57 AM
Oneiroi
May 20, 2002 04:38 PM
