ZC or B16 on 89 Si?
B series has much part support, So does ZC, thing about ZC is that the parts are a mix and match from Japan. Either way you will probably have fun with each of them. ZC is cheaper overall.
ZC yo!
I used to have an 89 si with a ZC in it! The engine is cheaper than a b16 and in that car it's a lot of fun!
The swap is easier too, because you don't have to deal with all the wiring that you would have to deal with with a b16.
If it is an Si already then the wiring is VERY easy, just 4 wires.
I'd say go b16 if you have the funds, if not then the zc is a good route to go.
