drum to disc conversion on 89 Si
Old Mar 3, 2004 | 06:21 PM
gNST03's Avatar
Default drum to disc conversion on 89 Si
I have an 89 Si and in need of help to do a drum to disc brake conversion. What parts do i need or which one is better? 92 to 95 civic trailing arms or 94 gsr trailing arms? also, i'm thinking of swapping the calipers in the front. any good ideas.
Old Mar 3, 2004 | 08:06 PM
kid-honda's Avatar
You can also use 90/91 crx Si rear disks.
Some people use 90/91 integra front knuckles and brakes for a upgrade and some use the 90/91 civic EX front knuckle and brakes.
The integra knuckles do have a little but different geometry so you will need to correct it some how.
Old Mar 4, 2004 | 02:09 AM
undefinedcrx's Avatar
Default Re: drum to disc conversion on 89 Si (gNST03)
use the 90-91 trailing arms. also, you need the brake lines off the 90-91.
Old Mar 4, 2004 | 05:29 AM
xxtegra's Avatar
Default Re: drum to disc conversion on 89 Si (undefinedcrx)
http://www.fourthgenhatch.com/mpfi.html
look around here you will find excectly what u want
Old Mar 4, 2004 | 05:40 AM
Mr Furball's Avatar
You can use all 90-93 integra parts. Just use the whole assembly with the e-brake cables.
Old Mar 4, 2004 | 05:54 AM
virginia_dude's Avatar
Here is everything you need to know. http://www.fourthgenhatch.com/reardiscswap.html
Old Mar 5, 2004 | 08:14 AM
gNST03's Avatar
Default Re: drum to disc conversion on 89 Si (virginia_dude)
thanks guys
Old Mar 5, 2004 | 08:54 AM
warchild69's Avatar
you may use "any" 90 to 2000 model integ. rear trailing arms with the cables.... you will need all hardware including brake pads, calip's, cables, and you may use your lower control arm if you wish.... if you use the integ ones then you must get the struts to fit the teg.... same size and all.... just different bottom portion where the strut meets the arm..... i have 2000 rear disc on my 88 crx si which did not come with disc in the back until later.... hope this help and that will fit for a fact.....
Old Mar 5, 2004 | 10:16 AM
EL Vap133's Avatar
Do you have an Si hatch or CRX?
Old Mar 5, 2004 | 10:50 AM
gNST03's Avatar
Default Re: drum to disc conversion on 89 Si (EL Vap133)
i have the Si. is it possible if you can send me pix of urs EL Vap 133? pls. send it to jaynochegarcia@aol.com. thanx. how much it cost you to do everything using the 2k teg trailing arms?
Old Mar 5, 2004 | 11:59 AM
warchild69's Avatar
$100.00 per side is what the junk yards here get..... that is not too bad... also get the "4040" proportioning valve and replace the one you have..... it will have the 4040 stamped on it......get the yard to throught it in.... they only get about 10.00 for it anyway....
Old Mar 5, 2004 | 12:04 PM
CRXified's Avatar
Default Re: drum to disc conversion on 89 Si (warchild69)
how hard is it to take the 90-91 rear disc from an Si rex and put it onto a 89 Si?
if i can get teh training arms and struts and rotors and calipers all attached, waht else do i need to do?
do i need a porportioning valve, or should it have 1 already?
thx
Old Mar 5, 2004 | 12:07 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gNST03 &raquo;</TD></TR><TR><TD CLASS="quote">i have the Si. is it possible if you can send me pix of urs EL Vap 133? pls. send it to jaynochegarcia@aol.com. thanx. how much it cost you to do everything using the 2k teg trailing arms?</TD></TR></TABLE>
Yes I know you have an Si, but is it an Si Civic hatch or crx?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to take the 90-91 rear disc from an Si rex and put it onto a 89 Si?
thx</TD></TR></TABLE>
If you get them from another crx si, use the ebrake cables, trailing arms, rotors, calipers & bracket, pads, and prop valve, and for the rest you can use your stock stuff.
Old Mar 5, 2004 | 05:42 PM
warchild69's Avatar
yea man i you can find the cables and all the other from a crx then that would be good .... if not then you will have cables that are about 6" too long.... no prob though... just route them witha little bit of creativity...... you may use your prop. valve but will notice a big difference with the teg. one with the 4040 on it..... to my best knowledge all the teg's without abs should have the 4040 valve.... dont forget to bleed your whole system!!!!
Old Mar 5, 2004 | 10:25 PM
risiah05's Avatar
SO DOING A FIVE LUG COVNERSION SHOULD BE THE SAME THING OR CLOSE TO IT, CORRECT?
Old Mar 5, 2004 | 10:55 PM
B2FiNiTY's Avatar
Default Re: drum to disc conversion on 89 Si (risiah05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risiah05 &raquo;</TD></TR><TR><TD CLASS="quote">SO DOING A FIVE LUG COVNERSION SHOULD BE THE SAME THING OR CLOSE TO IT, CORRECT?</TD></TR></TABLE>
nothing close to it.
Old Mar 5, 2004 | 11:04 PM
risiah05's Avatar
Default Re: drum to disc conversion on 89 Si (B2FiNiTY)
from what i read..the whole assembly is needed for the five lug...most are bolt-on...how far different is it?
Old Mar 7, 2004 | 08:45 AM
CRXified's Avatar
thansk EL Vap133, thats waht i needed.
i just got 1 question, where is the prop. valve located and how can i tell if i should get a new for or not?
Old Mar 7, 2004 | 09:36 PM
gNST03's Avatar
i have the hatch.
Old Mar 8, 2004 | 11:24 AM
CRXified's Avatar
anybody???
Old Mar 8, 2004 | 11:28 AM
crx_88_si's Avatar
prop valve is located on the pass side strut tower inthe engine bay. if your car had drums from the factory i'd get the disc (known as 4040) prop valve.
Old Mar 8, 2004 | 11:58 AM
Default Re: (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">prop valve is located on the pass side strut tower inthe engine bay. if your car had drums from the factory i'd get the disc (known as 4040) prop valve.</TD></TR></TABLE>
I second that. you need this so your brakes are properly balanced fron to rear.
Old Mar 8, 2004 | 03:07 PM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
http://www.fastbrakes.com/products/&lt;------------has a kit...
B18_Civic
Jun 1, 2016 06:56 AM
dohc_zc_build
Mar 15, 2010 01:12 PM
freak86
Apr 12, 2008 11:55 AM
jdmEF91
May 22, 2006 10:59 AM
jb0705
May 16, 2006 11:00 AM
