CLUTCH CHATTER WITH SPOON CLUTCH?
Old Mar 3, 2004 | 05:43 PM
crazy eyez killa
Guest
Posts: n/a
Default CLUTCH CHATTER WITH SPOON CLUTCH?
I HAVE A SPOON SPORT CLUTCH KIT IN MY B16 WITH AN ACT FLYWHEEL
I EXPERIENCE CLUTCH CHATTER AT VERY LOW RPMS LIKE WHEN IM LETTING OUT THE CLUTCH PEDAL
IS THIS NORMAL, HAS ANYBODY ELSE W A SPOON CLUTCH EXPERIENCED THIS
I KNOW ITS NORMAL FOR 4 PUCK CLUTCHES AND ETC BUT SPOON LOOKS LIKE STOCK
Old Mar 3, 2004 | 06:49 PM
emoney9's Avatar
Default Re: CLUTCH CHATTER WITH SPOON CLUTCH? (KURRRWA)
the reason it chatters is because your flywheel is lighter, just give a little more gas and you're golden.
Old Mar 3, 2004 | 07:11 PM
Sliced Beard's Avatar
Default Re: CLUTCH CHATTER WITH SPOON CLUTCH? (emoney9)
it is chattering because you are yelling at it
dude please turn your caps. lock off
and like my man said
a lighter flywheel matched with a more aggressive clutch = chatter unless you do what i do and instead of starting out with such a low rpm give it a little more rpm and you will find that it all smooths out
Old Mar 3, 2004 | 08:21 PM
crazy eyez killa
Guest
Posts: n/a
Default Re: CLUTCH CHATTER WITH SPOON CLUTCH? (dirtyd463)
cool sounds good jsut had to reassure myself
ill stop yelling
Old Mar 4, 2004 | 02:48 AM
kidkombo's Avatar
could the chatter be because the flywheel wasnt resurfaced?
Manguish
Jun 14, 2003 01:26 PM
98R-1144
Sep 1, 2002 06:02 PM
Integra_B18B
Mar 15, 2002 01:43 PM
wdyno
Oct 23, 2001 11:39 AM
EleanoR
Sep 6, 2001 12:09 PM
