B Series Fuel Pump Install
Old Mar 3, 2004 | 04:38 PM
Civmochris's Avatar
Default B Series Fuel Pump Install
i need to know what needs to be done to install a b series fuel pump into a 88 crx si it doesnt have any wires on the fuel pump itself is it plug and play i know that you have to drop the tank and every thing like that i am wondering about wireing thanks
Old Mar 3, 2004 | 05:03 PM
Civmochris's Avatar
Default Re: B Series Fuel Pump Install (Civmochris)
Anyone
Old Mar 3, 2004 | 06:08 PM
StorminMatt's Avatar
Replaciong the fuel pump is not the simplest or funnest job in the world on a CRX. The big problem? Honda did not decide to make it easy by installing an access plate until 1992. So you have to drop the tank to get at the pump. Then, you just remove the bracket and replace the pump with a higher flow unit. The difficulty of this varies with the pump you use.
Old Mar 3, 2004 | 07:18 PM
Spartanic's Avatar
Your probably better off looking for instrucions in a Haynes or Helms manual. You can get them at your local auto parts store. Be sure to read the safety stuff on fuel pump remoing and installation in the manuals.
Old Mar 4, 2004 | 09:13 AM
Austin's Avatar
Here's some advice:
https://honda-tech.com/zerothread?id=785166
lostforawhile
Welding / Fabrication
19
Mar 12, 2011 10:18 AM
jdm4drSi
Jun 12, 2007 08:21 AM
Cute EK
Jan 6, 2006 09:06 PM
trooper0641
Jul 13, 2005 08:21 PM
turbohf
Feb 8, 2003 07:52 AM
