motor mounts please help!!! asap!!!
Old Mar 3, 2004 | 04:16 PM
B16_eg's Avatar
Default motor mounts please help!!! asap!!!
i have a 95 civic si and im putting in a stock 93 motor what front motor mount do i need? the mount from a 93 or from a 95 sohc vtec? they are different and i think im using the 93 mount right now and it wont fit. thanks skye
Old Mar 3, 2004 | 07:50 PM
Kataku2K3's Avatar
Default Re: motor mounts please help!!! asap!!! (B16_eg)
The '95 upper mount (part that bolts to the chassis, NOT block) is the exact same as '94-2001 Integras... I know what you're saying about the '93 mount as it looks/is entirely different... If this motor you're putting in is a complete motor go ahead and just use the '93 mount (it's geometry is the exact same)... If you want to use the '95 then you'll need to take off that motors timing belt cover and use both mounts (one that bolts to the block and the upper part that bolts to the chassis)... Sorry for being so confusing, just trying to clarify...
b@tman
Mar 15, 2009 08:41 AM
bondcar
Apr 23, 2007 05:52 AM
zeke mccune
Jun 1, 2004 05:04 PM
