parking break light is out but works
hi, well im kinda confused... when i turn my parking lights on,.. only the right headlight turns on.. so you would just think that the right headlights bulb was burnt out right? nope, the right turn signal works fine which uses the same bulb as the parking breaks do. Do you think thereis a fuse that blew or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcom »</TD></TR><TR><TD CLASS="quote">hi, well im kinda confused... </TD></TR></TABLE>
So am i .....my head hurts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcom »</TD></TR><TR><TD CLASS="quote">so you would just think that the right headlights bulb was burnt out right? nope, the right turn signal works fine which uses the same bulb as the parking breaks do. </TD></TR></TABLE>
So why would we think that the headlight is out..if its a parking light problem?
wtf did you just say? are you referring to the tail light? if i recall correctly, the bulbs in the tail lights are dual filiment, which means one is one when the running lights are on, and then the other filiment lights up when you hit the breaks. if say the running light is out, that doesn't necessarily mean the break light is out.
hopefully i cleared some things up. otherwise, i dont know what your saying.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xcom »</TD></TR><TR><TD CLASS="quote">hi, well im kinda confused... when i turn my parking lights on,.. only the right headlight turns on.. </TD></TR></TABLE>
what? are these the same as running lights, or bwahhhhhhaaahhhh
help us and we can help you....
ep3hatchblack
Mar 20, 2004 12:14 AM
