what suspension upgrade for my 89 crx?
Just curious on what upgrade people have gone with there crx and what they reccommende.........i have about 500-600$ to spend........ and my stock suspension has about 195 k on it......def needs it. Thanx peeps
def throw in a rear strut brace.. best 20 bucks i spent on mine ..
also i hear alot of people that say done mess with the front sways to much because it could make your car plow ? although ive never tried this .. im just going by what ive heard on HT.. becarefull what rear sway you chose (if you do) because it may have conflicts with your exhaust .. first tell us what you want your car to do .. this will help others to set you in the right direction!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndGenREX »</TD></TR><TR><TD CLASS="quote">Just curious on what upgrade people have gone with there crx and what they reccommende.........i have about 500-600$ to spend........ and my stock suspension has about 195 k on it......def needs it. Thanx peeps</TD></TR></TABLE>
Ground Control coilover sleeves with custom spring rates and Koni Sport dampers is the best bang-for-the-buck suspension setup you can buy. This is a proven setup, used by countless amateur road racers and autocrossers. I highly recommend it.
Just save up another $200 and you'll be able to get this setup. http://www.ground-control.com Ground Control can help you choose your spring rates based on what you intend to do with the car; just ask them for advice when you call to order.
You'll thank me later.
Boosted Chemist
Suspension & Brakes
18
Aug 30, 2005 05:04 PM
Jdm_Rice_Monster
15
Nov 18, 2003 09:47 PM
