PL3/3000 or PL3/9000 Which is SI tranny #?
Old Mar 3, 2004 | 01:14 PM
SPORT INJECTION's Avatar
Default PL3/3000 or PL3/9000 Which is SI tranny #?
Reading searches ive read both... which is the casting # for a 90 si?
thanks
Old Mar 3, 2004 | 01:44 PM
BAZ's Avatar
BAZ
Default Re: PL3/3000 or PL3/9000 Which is SI tranny #? (SPORT INJECTION)
I've got the same question
Old Mar 3, 2004 | 01:47 PM
USDM 4G VTEC's Avatar
Si tranny's
PL3/1000
PL3/9000
PL3/3000
DX tranny
PL3/A100
PL3/A300
PL3/A900
any other codes is either a HF tranny or a 4 speed
Si trannies have the code number with just letters.. if it has letters and numbers is a DX
Old Mar 3, 2004 | 02:04 PM
BAZ's Avatar
BAZ
Default Re: PL3/3000 or PL3/9000 Which is SI tranny #? (USDM 4G VTEC)
Which codes correspond with which years though?
Old Mar 3, 2004 | 02:12 PM
Default Re: PL3/3000 or PL3/9000 Which is SI tranny #? (BAZ)
identify the year by the input shaft where the clutch goes into...
if it has 0 grooves is a 88
1 groove is a 89
2 grooves is a 90-91
Old Mar 3, 2004 | 06:07 PM
jlicrx's Avatar
these numbers PL3/3000, PL3/A000 have <U>nothing</U> to do with the gears that are inside - these are casting numbers for the back half of the L3 case - the 3000, 9000, etc. have the large differential bearings - the A000, A100, etc. have the small differential bearings - since most Si's have the large bearings, most with 3000, 9000, etc. will be Si, but not all - i happen to have 2 ZC transmissions, one PL3/3000 and one PL3/9000 - i have taken a PL3/A000 out of a one owner 88 CRX Si with 78,000 miles on it, to do a swap and it was definitely Si, with small bearings - have also had a PL3/3000 from a 91 CRX DX that was a DX transmission with the large bearings - also have a 4 speed from 89 STD hatch that is PL3/A000 - the only way you can tell for sure is by the gears
Old Mar 4, 2004 | 05:59 AM
Default Re: PL3/3000 or PL3/9000 Which is SI tranny #? (jlicrx)
checked my extra tranny last night and it is PL3/3000.... so I guess I should be cool....
now time to crack it open
bigginsUT
Jan 4, 2007 12:43 AM
ViperRedCRX
Nov 11, 2003 07:05 AM
Bigjussin
Sep 27, 2003 05:24 AM
Wes d
18
Jun 6, 2003 08:53 PM
keithv
11
Apr 11, 2002 06:34 AM
