koni yellow's on integra
Old Mar 3, 2004 | 12:42 PM
t0ekn3e's Avatar
Default koni yellow's on integra
my friend just got a set of used koni yellow and we cant put the cap on any suggestion?
Old Mar 3, 2004 | 12:46 PM
reno96teg's Avatar
can you be a little more specific? i don't know what you're talking about.
Old Mar 3, 2004 | 12:49 PM
t0ekn3e's Avatar
i think its called the shock mount the black metal cap that goes on top of the shocks thanks
Old Mar 3, 2004 | 01:07 PM
k279's Avatar
Default Re: (t0ekn3e)
Are you using a spring compressor?
Old Mar 3, 2004 | 01:13 PM
t0ekn3e's Avatar
no we're not but the shock mount doesnt even go on all the way
Old Mar 3, 2004 | 01:20 PM
reno96teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">i think its called the shock mount the black metal cap that goes on top of the shocks thanks</TD></TR></TABLE>
do you mean the dust cover (#12 in the picture below)? if so, i had to drill the opening a bit for the shaft to fit through.
Old Mar 3, 2004 | 01:22 PM
t0ekn3e's Avatar
its #17
Old Mar 3, 2004 | 01:36 PM
96 Ls lnTeG's Avatar
Default Re: (reno96teg)
Did you swap out part 14 ????
Old Mar 3, 2004 | 01:37 PM
t0ekn3e's Avatar
how would you take that out? its the metal ring in side the bushing right?
Old Mar 3, 2004 | 01:56 PM
Groove_D's Avatar
what springs you are using?
Old Mar 3, 2004 | 01:59 PM
t0ekn3e's Avatar
h&r racing
Old Mar 3, 2004 | 02:26 PM
96dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">its #17</TD></TR></TABLE>
You mean 9? 17 is a nut.
Old Mar 3, 2004 | 04:38 PM
t0ekn3e's Avatar
it was 14 sorry but we got the shocks and springs on but once we drop it, it was hella low and we dont think its suppose to be like that
Old Mar 3, 2004 | 05:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">it was 14 sorry but we got the shocks and springs on but once we drop it, it was hella low and we dont think its suppose to be like that</TD></TR></TABLE>
where do you have the c clip on??? it where the bottom of spring sits you can move it up a 1/4"
Old Mar 3, 2004 | 05:33 PM
t0ekn3e's Avatar
how do you move the c clip
is this where the c clip would go?
Modified by t0ekn3e at 2:46 AM 3/4/2004
Old Mar 3, 2004 | 06:04 PM
from the look of the pic it looks like you already have it on the highiest setting, so your choices are get new springs( Cough... Ground Controls) Pm me Let you know where you can get Ground Control for Koni's for 300
Old Mar 3, 2004 | 06:12 PM
xdavidx's Avatar
Default Re: (96 Ls lnTeG)
that cant be the highest setting because that is the bottom of the shock right there and where the arrow is going towards the top of it...is there a way we can take that clip out and move it up???
Old Mar 3, 2004 | 06:13 PM
t0ekn3e's Avatar
that at the bottom of the shock so i don't think its the lowest setting
Old Mar 3, 2004 | 06:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0ekn3e &raquo;</TD></TR><TR><TD CLASS="quote">that at the bottom of the shockso i think its the lowest setting</TD></TR></TABLE>
From your pic I saw the silver clipbut get a pair of needle nose pliers an move it up to the middle... or top to your preference
Old Mar 3, 2004 | 06:26 PM
t0ekn3e's Avatar
that silver clip it a ring and it slides up and down quite easy
Todd00
Suspension & Brakes
16
Apr 4, 2016 12:11 PM
Chillinit
Suspension & Brakes
Mar 18, 2008 11:53 PM
Jaybmoc
Suspension & Brakes
14
Jun 9, 2006 11:44 AM
MrCivic03
Honda S2000
Jun 22, 2005 04:01 PM
ophdehEEzY
Dec 29, 2003 08:53 AM
