Does blowing ware your motor? Supercharge?
Does supercharging cause or increases wear in your motor? Also how about comparing both N/A, Turbo, Nitrous, and Blow in a wear comparision thanks
Ladies and gentlemen we are floating in space...
FI can wear your engine, and it's also possible for the motor to hold up completely fine. If you're not pushing crazy pressures, if you have your motor built right, and if you have the right fuel management, forced induction is fine. The question isn't really detailed enough though.
Try looking around the FI forum.
