Question about B16a
ok my friend swapped a b16a in his 90 hf well he got it running and eveything but the car would rev to like 7500 and wouldnt go anymore like it didnt have power after then well it was getting worst and worst and now it will not even go into vtec...but he can do a burnout and it will go into vtec so im lost on what it can be....he has a brand new warlbro F/P.
i said new f/p so people wouldnt say its the prob. but now it wont go into vtec so there is a prob and there is no CEL auto ecu wouldnt cause it to get worse and worse its like there isnt enough fuel supply for when the vtec kicks.
i didnt say while reving i said while doing a burnout.....you know not just sitting there but going a little but vtec will engage while revving in my car but thats cause i have a rpm switch.But im looking for answers to my question.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr »</TD></TR><TR><TD CLASS="quote">ok my friend swapped a b16a in his 90 hf well he got it running and eveything but the car would rev to like 7500 and wouldnt go anymore like it didnt have power after then well it was getting worst and worst and now it will not even go into vtec...</TD></TR></TABLE>
RUN ON SENTANCE, because you dont use punctuation I am left to assume your reving the **** out of your car just to hit vtec. vtec only engages while driving.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bserieskllr »</TD></TR><TR><TD CLASS="quote">but he can do a burnout and it will go into vtec so im lost on what it can be....he has a brand new warlbro F/P.</TD></TR></TABLE>
again, you now make it sound like during a burn out it will engage, but while reving it wont.
You failed to mention an RPM switch, we were left to assume stock b16a. But are you talking about your car or your friends. If your talking about yours, stop trying to be right about everything ~ because you apparently cant fix the problem yourself on your friends car.
If your friend has the RPM switch, tell us what other mods have been done, especially electronically.
OK ill try again sorry.....When we first did his swap he didnt have vtec hooked up. We then took it for a test drive and it would not go past 7500 while driving. So after he got vtec hooked up we went for another test drive and vtec engaged but then it would not go past 6500 well after driving it more the car just sputters where it supposed to go into vtec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vero »</TD></TR><TR><TD CLASS="quote">
vtec can't engage while revving? That's the first time I've heard that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kim_2_da_chee »</TD></TR><TR><TD CLASS="quote">
It's one of the constants. You have to be going at around 15mph, have a high enough oil pressure, and you must be at the correct RPM, as well as have a warm enough motor.
</TD></TR></TABLE>It's one of the constants. You have to be going at around 15mph, have a high enough oil pressure, and you must be at the correct RPM, as well as have a warm enough motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VashTheStampede »</TD></TR><TR><TD CLASS="quote">
It's one of the constants. You have to be going at around 15mph, have a high enough oil pressure, and you must be at the correct RPM, as well as have a warm enough motor.</TD></TR></TABLE>
There were many cases where my friends 99 sir or integra type r or 2001 preludes all engaged vtec when just revving. they had to rev past 5K for it to engage.. i dont believe that you have to me "in motion" for it to engage.
Watch some drag racing... (if there is any races goin on late at night in your area), lots of kids drop the clutch at over 5K... while they are "in vtec"... there is a distinctive sound that im sure you all know, and you can hear it before the actually drop the clutch
anyways, im making this too long. if im wrong, what ever.
Thats why it needs a VSS signal to trigger the car is moving. No signal amoung a few others and no Vtec.
</TD></TR></TABLE>Thats why it needs a VSS signal to trigger the car is moving. No signal amoung a few others and no Vtec.
user 25438239
37
Jan 2, 2007 09:02 AM
b18crxturbonitrous
28
Sep 1, 2004 11:14 PM
