Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
tire question from novice
Old Mar 3, 2004 | 09:13 AM
ImprtTuner88's Avatar
Default tire question from novice
ok, finally gonna give autox a try. There is one coming to Wilmington, nc this coming sunday. My question is simple, the car is all stock so I know that I will be in HS class. My question is about tires, it is the only thing I am unsure of. I have some 195/50/14's Firehawk tires mounted on 14" OEM CRX Si wheels. What psi should I run at this course as it is a parking lot that is kinda rough b/c of its age.
any suggestions and or comments welcome!
Old Mar 3, 2004 | 09:15 AM
.RJ's Avatar
.RJ
Default Re: tire question from novice (ImprtTuner88)
I would go to 45psi
Old Mar 3, 2004 | 09:24 AM
tnord's Avatar
Default Re: tire question from novice (.RJ)
40 or more.
Old Mar 3, 2004 | 09:28 AM
Default Re: tire question from novice (tnord)
wow, that high, wouldn't have guessed that, what is the theory, explanation of running such high psi?
just trying to understand.......
thanks for the input guys!
Old Mar 3, 2004 | 09:33 AM
.RJ's Avatar
.RJ
Keeps the tire from rolling over onto the sidewall
Old Mar 3, 2004 | 09:57 AM
tnord's Avatar
typical street/all season tires have a much softer sidewall than performance oriented tires. as RJ said, it helps to keep the tire from rolling over onto its sidewall, keeping more of the tire on the road.
you can actually tweek handling characteristics by playing with tire pressures, but i don't think you need to start messing with that just yet.
i would say inflate them to 40 cold, check them hot after a run and see what has changed. it might not change at all, or they might gain a few psi. either way, i wouldn't go over 45 hot.
Old Mar 3, 2004 | 10:34 AM
thank you all very much. I have been wanting to try auto-x for years and have never had the time and was always afraid of tearing something up. BUT, i have lots of spare parts for my 90' so it is all good.
I have alot of my students (yes I am a HS shop teacher) planning on coming to watch and a few wanting to participate. It looks to be a fun weekend. About 40 cars have signed up thus far so hopefully we have a good turnout.
http://www.ncrscca.com/Pdf/MAR...R.pdf is the link for the event.
Old Mar 3, 2004 | 10:42 AM
.RJ's Avatar
.RJ
Good luck!
Be weary of the go-fast crack pipe... its addicting
Old Mar 3, 2004 | 10:51 AM
Crack Monkey's Avatar
Get your students to build you an autocross beast. That would be sweat.
tnord's Avatar
have fun.
before you know it you'll be having your high school minions fabricating parts for your car in exchange for seat time.
Old Mar 3, 2004 | 10:54 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tnord &raquo;</TD></TR><TR><TD CLASS="quote">before you know it you'll be having your high school minions fabricating parts for your car in exchange for seat time. </TD></TR></TABLE>
Thats worse than selling them crack
Old Mar 3, 2004 | 12:07 PM
Steppin Razor's Avatar
New User
A good way to check sidewall rollover is to chalk them (I've found that lumber crayon works pretty good for this). Put ~4 marks on the tire, going from a few inches on the tread to a few inches onto the sidewall. If the marks wear off on the sidewall, increase pressures. If the mark still shows on the tread part, lower pressures. Adjustments should be small (1,2,3, psi at a time). I suspect you won't need as high pressures in the rear as the front.
Old Mar 3, 2004 | 12:28 PM
Targa250R's Avatar
be professional
By chance, what car is this? It's not the car listed in your signature, is it?
Old Mar 3, 2004 | 05:56 PM
Default Re: tire question from novice (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">By chance, what car is this? It's not the car listed in your signature, is it?</TD></TR></TABLE>
yes it is............LOL, just wanting to have a little fun, not gonna tear it up obviously
lol..........
Old Mar 4, 2004 | 05:52 AM
tz-devil77's Avatar
I dont think the car really matters. There are lots of suprises in my old eight valve motor!!!!!!!!!. We also have a garage full of upgrades for the beater so we/he is gonna blow this one up right now then time to go faster.
and yes the go fast bug is already in our blood!!!!!!
Old Mar 4, 2004 | 08:39 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImprtTuner88 &raquo;</TD></TR><TR><TD CLASS="quote">
lol..........</TD></TR></TABLE>
The reason I asked was because that car is not legal for Stock class. I believe you will have to run CSP.
Old Mar 4, 2004 | 09:13 AM
why is it not legal for stock class? it is stock std hatch with the d15b in it, dual point injection, everything. The MPFI swap has not been performed yet (next week) and the B16 swap is happening in june or july.................
btw, I really appreciate all this info, I have enjoyed all the threads in this forum as you auto-x guys I find to be VERY helpful and very eager to share knowledge and don't talk bs etc. for that I thank you guys!
Old Mar 4, 2004 | 09:15 AM
actually to get technical it is the 8valve motor out of an HF crx and the 5spd with it, I bought the car for $100 with a bad motor, and got the motor and trans for free.
would the fact that the motor is out of a lesser car kick it out of stock class?
Old Mar 4, 2004 | 09:21 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImprtTuner88 &raquo;</TD></TR><TR><TD CLASS="quote">would the fact that the motor is out of a lesser car kick it out of stock class?</TD></TR></TABLE>
Yeah but who cares just go have fun
Old Mar 4, 2004 | 09:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Yeah but who cares just go have fun </TD></TR></TABLE>
true, true
Old Mar 4, 2004 | 09:27 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImprtTuner88 &raquo;</TD></TR><TR><TD CLASS="quote">actually to get technical it is the 8valve motor out of an HF crx and the 5spd with it</TD></TR></TABLE>
If it is a D15B2, as you have listed, it came from a Civic (or CRX) DX, and you would be legal for CSP (C-Street Prepared). Also, the 14" wheels aren't legal for stock class.
If it is a CRX HF engine (D15B6), you would have to go to SM (Street Modified).
Just a few classing rules technicalities. Don't worry about the class you end up in, just concentrate on driving and having fun.
Old Mar 4, 2004 | 09:32 AM
ahhhh, that makes sense................I am sure if I searched I could find it, anybody have a handy link that easily breaks down the classes?
Old Mar 4, 2004 | 09:51 AM
Vracer111's Avatar
Default Re: tire question from novice (Crack Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">Get your students to build you an autocross beast. That would be sweat.</TD></TR></TABLE>
yeah, it would be the students sweat...
Maybe can start something like colleges have with Formula SAE ... would be cool at least and keep a few kids from turing to the Bling side by Ed-ju-ma-kateing them....
Old Mar 4, 2004 | 11:10 AM
Utilitarian's Avatar
Do what I did with the Tarheel Sport Car Club (raleigh) and when registering, tell the folks taking the money what your car is and the mods you have. They'll make sure you are taken care off. Have fun and try not do get too addicted like I did.
Old Mar 7, 2004 | 05:58 PM
Default Re: tire question from novice (Stock97ITR#50)
race was awesome, the left me in HS class, 9 cars in that class, I was severly underpowered (good ole 70hp 8valve motor!) but I managed to finish 5th with a 51 sec run, I was extremely happy. I learned alot about airpressure and about running the right lines and setting yourself up for the next corner. Thanks for all the advice guys!
here is my on my best lap.
