Question about Auto Power bar fitting in 91 crx si!?
Old Mar 3, 2004 | 08:42 AM
GreenMachineRex's Avatar
Default Question about Auto Power bar fitting in 91 crx si!?
ok i have heard that the door panles don't fir on with a auto power 4pt. roll bar. can anyone confirm this?
Old Mar 3, 2004 | 12:33 PM
Default Re: Question about Auto Power bar fitting in 91 crx si!? (GreenMachineRex)
B U M P !!!!
Old Mar 3, 2004 | 06:30 PM
bump please help me out.
Old Mar 3, 2004 | 06:42 PM
XrcR6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenMachineRex &raquo;</TD></TR><TR><TD CLASS="quote">ok i have heard that the door panles don't fir on with a auto power 4pt. roll bar. can anyone confirm this?</TD></TR></TABLE>
The door panels don't come into play... Think about it, the 4 point Autopower part is a roll bar not a full cage. It's the main hoop (that mounts to the floorpan behind the seats) and two down tubes into the hatch (actually go through the rear speaker holes). That should be the only thing necessary to remove, the rear speakers and covers. So if it is a) the correct part and b) installed properly, the whole assembly should be out of the way of the doors.
What you may be hearing about has to do with the 6pt. cage, depending on... If it was a design for the 88's with the thinner door panels with map pockets or it accomodates the later cars with thicker door panels (due to the encapsulated seat belt retrators/hardware). The door bars may be a tight fit in that case. A friend had the original design in his 88 and it would not fit my 91, but when I ordered they addressed this with different door bars.
Old Mar 4, 2004 | 07:11 AM
Default Re: Question about Auto Power bar fitting in 91 crx si!? (XrcR6)
T H A N K Y O U .
boostedcivicsir
Feb 18, 2010 07:14 PM
_bB
Jun 24, 2004 08:29 PM
jes c
Apr 12, 2004 04:07 AM
GreenMachineRex
Apr 4, 2004 04:24 PM
kHoA DoGG
Oct 15, 2002 08:01 PM
