p28 ecu problem
i have just converted my 99 dx/vtec (y8 head) to obd I p28 then car does not idle when cold its hard to start and timming seems to retard it self for no reason this is not all the time but often why can this be?!?!
yes i have done the re-wiring for the two wires configuration (ex iacv) injectors are my stock d16y7 ones, im almost sure they are all the same cc's thanks
where can I get more information on this i have heard from alot of people that all d series and even b series injectors are the same cc's any body knows this? thanks
can anybody tell me where to double check this? but either way if in fact the injectors are not 240cc will that be the cause of it not to iddle right? when i had my obd II ecu (ex P2P) i was getting code 45 CEL (too rich or too lean) can this be why? thanks alot for your help
That's definitely why you were getting the code and would explain the idle problems... You can check injector sizes on the ACCEL website... They have a spreadsheet with stock injector sizes if you look around...
EK79
May 27, 2007 01:48 PM
no show all go
Mar 15, 2002 07:22 PM
