aem v2 cai install on 02+ civic si?! pls help!
aem v2 is not a classic cai and doesn't require any cutting. just remove the stock airbox and bracket and put in the v2... the only problem you might have is if you have a strut tower bar - but that would only cause you to twist things around while installing. no big deal.
mine works great - but the gains are up top. i don't know if i lost any down low but i don't think i gained any down there. i'm going to dyno and see.
http://www.k-series.com/tech_d...N_CAI
That might help. It's basically the same install except you don't have to relocate the fuse box. And it's actually easier since it's a short ram intake.
