b16 pistons in b18c1
From: INZANE FOR PRESIDENT 2008 .., las vegas nv, U.S.of.A
i have people tell me that i need
1) Pistons
2) Rings
3) Rod bearings
4) head gasket
can anyone add to this can someone give me a price on this thx for the help.
1) Pistons
2) Rings
3) Rod bearings
4) head gasket
you will need
head gasket
head studs
rings
pistons
bearings (ALL)
bore/hone
you will also need a lot of other gaskets, new cotter pins, and various nuts and bolts if you really want to do it right, in addition to new fluids.
it is not worth it for 10whp. If you are going to take the block apart, only do so if you already have a VERY aggressive cam profile OR will be boosting or nawzing. Otherwise keep building up other areas. If you are so budgeted you can only afford b16 pistons, alone, you do not want to risk taking it all apart and having the rings not seat.
head gasket
head studs
rings
pistons
bearings (ALL)
bore/hone
the only reason i want to put b16 pistons is because my car uses up oil due to my rings and since im going to open the block just to replace rings i thought might as well put b16 pistons in there to give it a little more power i dont want to have a built gs-r that i have to go around filling up every 2 days i just want it to get me from point a to point b reliably fast....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inzane »</TD></TR><TR><TD CLASS="quote">the only reason i want to put b16 pistons is because my car uses up oil due to my rings and since im going to open the block just to replace rings i thought might as well put b16 pistons in there to give it a little more power i dont want to have a built gs-r that i have to go around filling up every 2 days i just want it to get me from point a to point b reliably fast....
LOL
</TD></TR></TABLE>LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Audio28 »</TD></TR><TR><TD CLASS="quote">why do you want to use b16 pistons</TD></TR></TABLE>raise compression a bit then later on build the head alittle and ill be done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr »</TD></TR><TR><TD CLASS="quote">
LOL
</TD></TR></TABLE>explain ur self are u typing **** just to post ***** or do u actually know something
LOL
yeah with b16 pistons he would yield a higher compresion ratio. I say go for it it
