205/50-15s vs 195/55-15s pros/cons of the sizes?
Old Mar 2, 2004 | 07:53 PM
yoda888's Avatar
Default 205/50-15s vs 195/55-15s pros/cons of the sizes?
Hey all,
I'm looking for a new set of track tires. Given that they will go on a stock 15" GSR rim, same brand/model of tire. SO the only difference would be tires size.
Pros & Cons?
195/55s
Pros:
-stock size
-"softer" ride compared to 205s
-cheaper $$ compared to 205s
Cons:
-taller sidewall compared to 205s, which means more sidewall flex
205/50s
Pros:
-stiffer sidewall vs. 195s in terms of performance
Cons:
-not a 100% match in diameter
-cost more $$ compared to 195s
So, aside from the ride, I guess the biggest question is, is there any performance difference between 205/50 and 195/55?
Thanks!
Old Mar 2, 2004 | 08:25 PM
Chris y0!'s Avatar
Default Re: 205/50-15s vs 195/55-15s pros/cons of the sizes? (yoda888)
195s fit the rim better and therefor handle better. they are also cheaper.
205s have more grip for drag racing i guess...
Old Mar 2, 2004 | 08:28 PM
yoda888's Avatar
Default Re: 205/50-15s vs 195/55-15s pros/cons of the sizes? (Chris y0!)
Awesome..the purpose of these tires won't be for draggin, but for HPDE...
So 195/55s it is then! Save myself some money too!
Any other comments or thoughts?
Old Mar 2, 2004 | 08:30 PM
typeRSXS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris y0! &raquo;</TD></TR><TR><TD CLASS="quote">195s fit the rim better and therefor handle better. they are also cheaper.
205s have more grip for drag racing i guess...</TD></TR></TABLE>
205 will not help on 6" wide stock rims, the sides will curve up, therefore the full width of the tire is not on the ground. it might help a BIT, but WAY not worth it. stick with 195 on stock rims. 205, is a bit wide for 6.5", PERRFECT for 7", dont think about 205 for 6" stockies
Old Mar 2, 2004 | 09:37 PM
Jason's Avatar
any reason this is in the ITR forum? Teg forum doesn't have tech questions anymore
Integra2316
Oct 15, 2011 12:26 PM
R00teg
Aug 2, 2009 06:16 AM
yoda888
Mar 3, 2004 07:20 AM
F120man
Oct 10, 2002 01:09 PM
brownman72000
Jun 22, 2002 08:38 PM
