85 crx si stock engine
Old Mar 2, 2004 | 06:18 PM
1gen crxer's Avatar
Default 85 crx si stock engine
ok my 1985 crx si have a 1.5 fi 12v dohc engine what is this i cant fond it anywere it redlines at 6500 ummm my speedomiter says 144 unlike most crx's say 120 mine says 144 umm thats it if you need anymore info ask it has 65k orignal miles on it too
Old Mar 2, 2004 | 06:37 PM
Blaze45's Avatar
Brrraaaap!
Default Re: 85 crx si stock engine (1gen crxer)
So what are you asking? I cant make sense out of your post. It sounds like your tryin to ask what RPM you redline @? You dont have a tach? Unless your making power up there, there isnt any point at all to rev that high.
Blaze
Old Mar 2, 2004 | 06:39 PM
1gen crxer's Avatar
ok i have an 85 crx si i took an engine out of it. The engine is a 1.5leter fuel injeted engine with 12 valves and its a duel over head cam, also my speedomiter says 144 unliek most crx's witch say 120 what engine is this because i have one with 65k miles on it
Old Mar 3, 2004 | 05:43 AM
crxfanatic's Avatar
New User
Default Re: (1gen crxer)
The 1985 CRX Si was the only year and model to get the special 140 speedo. Nice rare piece there!
As far as the motor, that is the stock 1.5 sohc 12 valve motor, rated at 92 hp. It is not a dohc...
Should look just like this (minus the header)
Old Mar 3, 2004 | 03:36 PM
1gen crxer's Avatar
ill look i think it says dohv on the top
Old Mar 3, 2004 | 03:38 PM
1gen crxer's Avatar
dohc sorry but yea how much is the speedo worth because im getting rid of the car is it worth taken out and selling on ebay or somthing
Old Mar 3, 2004 | 03:43 PM
1gen crxer's Avatar
your right sohc why did i think ti was a dohc why is the car so peppy if its a sohc motor like my friend has a sohc motor in his 95 civic and my car was faster then his by a lot
Old Mar 3, 2004 | 03:45 PM
Jet Black's Avatar
Default Re: (crxfanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxfanatic &raquo;</TD></TR><TR><TD CLASS="quote">The 1985 CRX Si was the only year and model to get the special 140 speedo. Nice rare piece there!
I'm pretty sure the 87 si engine was the only one to be fuel injected.
Old Mar 3, 2004 | 04:24 PM
wtsexton's Avatar
Default Re: (Jet Black)
You pretty wrong too. 85-87 Si was fuel injected. The 85 CRX Si was the first fuel injected car Honda sold here in the USA.
Old Mar 3, 2004 | 04:29 PM
crxgator's Avatar
Default Re: (wtsexton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wtsexton &raquo;</TD></TR><TR><TD CLASS="quote">You pretty wrong too. 85-87 Si was fuel injected. The 85 CRX Si was the first fuel injected car Honda sold here in the USA.</TD></TR></TABLE>
he is partially right...look at his country...in canada first year of the Si was 87...
Old Mar 3, 2004 | 05:15 PM
CyniKal.Mindset's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jet Black &raquo;</TD></TR><TR><TD CLASS="quote">
I'm pretty sure the 87 si engine was the only one to be fuel injected.</TD></TR></TABLE>
haha what do u think the "I" in "Si" stands for? INJECTED same as the "I" in GTi...and the "S" stands for Sports....so u get Sports Injected...hence Si being fuel injected
Old Mar 3, 2004 | 05:43 PM
wtsexton's Avatar
Default Re: (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">he is partially right...look at his country...in canada first year of the Si was 87... </TD></TR></TABLE>
Thats because Canda sucks. J/k
Old Mar 3, 2004 | 05:56 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1gen crxer &raquo;</TD></TR><TR><TD CLASS="quote">your right sohc why did i think ti was a dohc why is the car so peppy if its a sohc motor like my friend has a sohc motor in his 95 civic and my car was faster then his by a lot</TD></TR></TABLE>
The main reason why your car feels so much peppier is the fact that it is lighter. Your engine may only be 1.5 liters and have only 93HP, 95ft-lb torque. But the car weighs under 2000 pounds. A 1995 Civic can weigh well over 2200 pounds and has a 1.6 liter engine with 125HP, 106ft-lb torque at best (1.5 liter motors have only 102HP, 100ft-lb torque). So although power, torque, and displacement are better in the newer car, they are worse in comparison with the size and weight of the car.
Old Mar 4, 2004 | 03:18 PM
Jet Black's Avatar
I stand partially corrected.
baker1218
Classic Hondas
Aug 7, 2009 04:33 PM
toiletpaper
Nov 19, 2006 07:36 PM
aimmotorsports
14
Feb 13, 2006 05:53 PM
B18Redline
Jul 26, 2004 12:55 PM
Bobby12many
Mar 26, 2004 11:09 AM
