Energy Suspension
Old Mar 2, 2004 | 06:10 PM
SuperSlow's Avatar
Default Energy Suspension
I am a proud new owner of a 93 VTEC Prelude (traded my accord) and have been searching for threads on Energy Suspension bushings. I have come accross a couple threads that deal with the engine mounts, but I wanted to know if they were worth the money on preludes.
In the accord forum there is a mixed bag of opinions on which particular bushings to use. I also wanted to know if the installation was something that required hydraulic press or if it was something that can be done myself at home on jackstands....thanks.
Old Mar 2, 2004 | 06:24 PM
One Slow Lude's Avatar
Default Re: Energy Suspension (SuperSlow)
you can do it, and you can get them for like 35 bucks on here so its not that much and it helps eliminate wheel hop
Old Mar 2, 2004 | 07:08 PM
SuperSlow's Avatar
Thanks. I also was wondering if it was worth it to get the bushings for the control arms etc... to get everything replaced, or which?
THanks.
Old Mar 3, 2004 | 04:59 PM
SuperSlow's Avatar
Is this an old exhausted topic with the hyper flex master bushing set? or does nobody have it? anybody?
Old Mar 3, 2004 | 05:06 PM
Cottonwoodz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSlow &raquo;</TD></TR><TR><TD CLASS="quote">Thanks. I also was wondering if it was worth it to get the bushings for the control arms etc... to get everything replaced, or which?
THanks.</TD></TR></TABLE>
Not if you want your car to sound like, bed springs in a ***** house...
Old Mar 3, 2004 | 05:47 PM
SuperSlow's Avatar
Default Re: Energy Suspension (Cottonwoodz)
Someone posted in the accord forum that they were squeaky, but then they put some silicone grease on them and it was all good. Any opinions on the prelude?
Old Mar 3, 2004 | 06:12 PM
-Bionic-'s Avatar
Former Sponsor
Yeah use grease and you should be fine.
Old Mar 3, 2004 | 06:27 PM
specalk's Avatar
Default Re: Energy Suspension (-Bionic-)
no company has them for a 5th gen, it sucks
Old Mar 3, 2004 | 06:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Bionic- &raquo;</TD></TR><TR><TD CLASS="quote">Yeah use grease and you should be fine. </TD></TR></TABLE>
You will, for alittle while... Have fun regreaseing, and regreaseing.......
Old Mar 3, 2004 | 06:39 PM
RacingLude's Avatar
I have Energy Suspension on my 93 VTEC. They do squeak if you don't grease them. I keep a can of silicone spray that I give to my oil change guy to spray them everytime I get my oil changed.
Old Mar 3, 2004 | 07:52 PM
Spartanic's Avatar
Check out http://www.jdmgears.com for the Energy Suspension bushings.
Old Mar 3, 2004 | 08:06 PM
SuperSlow's Avatar
Default Re: Energy Suspension (Spartanic)
Or I could just hit up shaun311 and get it for less and shipped...
Old Mar 4, 2004 | 07:57 AM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">
You will, for alittle while... Have fun regreaseing, and regreaseing....... </TD></TR></TABLE>
I don't understand how that would be fun, but in the worst case scenario regrease them. It's not any more difficult than changing your oil.
Old Mar 4, 2004 | 04:11 PM
SuperSlow's Avatar
Default Re: (RacingLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RacingLude &raquo;</TD></TR><TR><TD CLASS="quote">I have Energy Suspension on my 93 VTEC. They do squeak if you don't grease them. I keep a can of silicone spray that I give to my oil change guy to spray them everytime I get my oil changed.</TD></TR></TABLE>
Did you install the master set yourself, or take it to a shop? If you did it yourself, any tips on getting the old ones out? If you took it to a shop, how long, and how much?
THanks.
Old Mar 4, 2004 | 06:39 PM
specalk's Avatar
Default Re: (SuperSlow)
Getting them out is hard my 92 se-r had a set and i looked for shops to install for a long time and no one wanted to do it so i just ended up having one of the techs at work do it. they used a press to get the old ones out.
I want one for my 5th gen dammit
i could care less about the noise takes a few mins to grease them but the advantages of having them in is night in day, best mod i did for my se-r with that LSD ground contol coilovers and koni shocks and ST sways car road light it was on rails and i did the bushings last and the results was amazing.
on my lude ive got st sways and TEIN HAs and i need a bushing kit any help on companys that make one of info on peiceing one together
Old Mar 4, 2004 | 11:08 PM
4gen's Avatar
Default Re: Energy Suspension (specalk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specalk &raquo;</TD></TR><TR><TD CLASS="quote">no company has them for a 5th gen, it sucks</TD></TR></TABLE>
Time to make some!!
mrvrsick
Jun 29, 2008 02:03 PM
keeganl
Feb 22, 2007 12:37 PM
Burke
Dec 16, 2003 09:42 AM
spoonfed95
Apr 9, 2003 03:14 PM
wuhungsixxx
Oct 5, 2001 11:03 AM
