Rear Wheel Bearing Fix
Old Oct 15, 2001 | 05:22 PM
zgrimes's Avatar
New User
Default Rear Wheel Bearing Fix
Any help or comments on replacing a rear hub assemby on a 94 Accord EX with rear disk brakes? Not sure where to begin. It seems like the assembly is accessed from the back, as the front appears to be sealed.
Old Oct 15, 2001 | 06:34 PM
BreakStuff's Avatar
New User
Default Re: Rear Wheel Bearing Fix (zgrimes)
Rear Hub assy. is accessed from the front.. you need to pry off the dust cover to see the nut that holds the hub in place..
Old Oct 18, 2001 | 07:32 AM
zgrimes's Avatar
New User
Default Re: Rear Wheel Bearing Fix (BreakStuff)
Swapped out the hub assembly last night. Very easy, rolls like a new one!
axis11
Aug 3, 2013 05:18 AM
thunderboy
Jan 27, 2009 01:34 PM
jason_alt
Nov 21, 2004 10:14 AM
Steve91
Aug 26, 2002 02:51 PM
