Putting together motor, do I fill around the sleeves with coolant?
Old Mar 2, 2004 | 05:20 PM
TeamCracka's Avatar
Default Putting together motor, do I fill around the sleeves with coolant?
I'm putting my B16 back together tonight, and I tipped the motor on a engine stand to dump all the coolant/oil mix out. I was wondering, should I fill the water jackets with coolant BEFORE I put the head on?
Thanks
Old Mar 2, 2004 | 05:23 PM
non-VTEC's Avatar
Default Re: Putting together motor, do I fill around the sleeves with coolant? (TeamCracka)
no you dont.......
once you start to fill the rad it will fill the entire engine block up.......no need to fill the sleeves.......
Old Mar 2, 2004 | 05:35 PM
TeamCracka's Avatar
Default Re: Putting together motor, do I fill around the sleeves with coolant? (non-VTEC)
Thanks
Old Mar 2, 2004 | 05:40 PM
99b18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">no you dont.......
once you start to fill the rad it will fill the entire engine block up.......no need to fill the sleeves.......</TD></TR></TABLE>
but u will have to bleed the air out. i had a bitch of a time doin this in a cavalier. not sure about the hondas though. basically u just run the engine. and shake the hell outta the car. it shouldnt take long to get all the air out.
Old Mar 2, 2004 | 05:54 PM
eyeamvic's Avatar
Default Re: Putting together motor, do I fill around the sleeves with coolant? (99b18)
Or you can go the smart route and leave the radiator cap off while it's warming up and let the air come out on it's own....
Old Mar 2, 2004 | 06:08 PM
MrBui's Avatar
Default Re: Putting together motor, do I fill around the sleeves with coolant? (eyeamvic)
there is a bleeder bolt on the motor
Mikey3000
Jun 23, 2008 04:31 AM
Civicracer17
May 10, 2006 09:26 AM
B18B00st
Jun 14, 2005 01:19 PM
spcrxracer
Feb 27, 2005 01:48 PM
drumsy
Sep 12, 2002 06:46 AM
