B20 Head On B16 Block
Old Mar 2, 2004 | 05:15 PM
TeamMGIperformance's Avatar
Default B20 Head On B16 Block
Can you put a B20B DOHC Non-Vtec head onto a B16 Vtec Block? If so what do I need to change and what oil pump do I use? Any one know
Old Mar 2, 2004 | 05:16 PM
non-VTEC's Avatar
Default Re: B20 Head On B16 Block (TeamMGIperformance)
why would you do this?
Old Mar 2, 2004 | 06:12 PM
deepgreengsr's Avatar
Default Re: B20 Head On B16 Block (non-VTEC)
maybe he did a conversion the other way around and wants something ot do with his left over parts.
Old Mar 3, 2004 | 10:47 AM
hair_rice's Avatar
cant say that i have ever seen anyone do that...so i guess i wouldnt have a clue how that works
Old Mar 3, 2004 | 11:07 AM
notstock93's Avatar
Default Re: B20 Head On B16 Block (hair_rice)
It can work. But you would be left with what is essentially a ZC motor that can rev like its going out of style....but it wont make any power.
Old Mar 3, 2004 | 05:05 PM
siffredi's Avatar
Bull **** what about putting a b20 built head like cam and port and polish and stuff and put it on a b18c block. you can put down lots of boost ,oil squirters, no V-tec to tune and the may both be left overs from a CRV-tec
Old Mar 3, 2004 | 05:14 PM
notstock93's Avatar
Default Re: (siffredi)
What do you mean built? Built as in crower 404's, hondata, and whatnot? Then you woud be left with......ta daaa..whats basically a VTEC head without the idle lobe. Not only would it still not be as good flowing as a VTEC head (without major port work), but he would be out a ton of money. And care to enlighten us on how his using a non-vtec head will allow him to run more boost?
Can it be done? Yes.
Should it be done? not unless you have money to burn.
Old Mar 3, 2004 | 07:33 PM
Kataku2K3's Avatar
Default Re: (notstock93)
You could do so and it wouldn't require much... I would take apart the motor as you will have to tap and plug the VTEC oil feed in the B16A block... You could use the stock oil pump as it has less to support but if you go back to running a nonVTEC ECU then swap a nonVTEC water pump on there as your motor will be working in a lower rpm range... Sorry, but to me this is a stupid idea... Tuning a nonVTEC motor isn't any easier than a VTEC motor so there's no benefit there... Also who want's to turn up the boost with stock pistons/rods... Yea the compression is going to go down somewhat as you gain 2.3cc's with the nonVTEC head but you're still working with cast parts... Overall I agree with notstock93 Just my $0.02
spens 91 Ef
Oct 29, 2009 11:40 AM
shotime
Jul 16, 2008 07:38 PM
b18hondahb
Oct 26, 2006 05:55 AM
photec2
25
Jan 22, 2004 12:12 PM
98TypeR
Sep 28, 2001 03:24 PM
