TB install/uninstall
Old Mar 2, 2004 | 04:27 PM
Wiseguy619's Avatar
Default TB install/uninstall
I installed a STR throttle body on my lude to see if they sent me the right one. If I put the old TB back on, will the car start up like normal?
Old Mar 2, 2004 | 05:21 PM
BluLude's Avatar
Default Re: TB install/uninstall (ProjectPenny)
if you did everything right no vaccum leaks and if you didn't break anything...then yes should be no problems
Old Mar 3, 2004 | 05:26 PM
Wiseguy619's Avatar
Default Re: TB install/uninstall (BluLude)
I hooked everthing up, and when I started the car my idle would bouce from 1-2. Could this be a vacuum leak problem?
speedfreek128
Honda S2000
Aug 9, 2015 08:25 PM
shabam
Aug 7, 2007 05:14 PM
9311dan
Mar 4, 2007 01:33 PM
00 FBP ItR
Aug 19, 2003 05:12 AM
