SRS light reset for the 94 model Accord
Old Mar 2, 2004 | 01:48 PM
one clean ride's Avatar
Default SRS light reset for the 94 model Accord
I did some research and found out that the 94 Accord has a different setup than the 95+ models. It does not haeve the MES connector that everyone uses to reset the light. Has anyone here reset their SRS light for the 94 Accord?
Old Mar 2, 2004 | 02:14 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: SRS light reset for the 94 model Accord (one clean ride)
there is no way to reset it. there is a fault in your srs sytem and it will not go away until it is corrected. unfortuneately only the dealer has the capacity to find the fault and fix it because a special test harness is needed
Old Mar 2, 2004 | 02:39 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one clean ride &raquo;</TD></TR><TR><TD CLASS="quote">I did some research and found out that the 94 Accord has a different setup than the 95+ models. It does not haeve the MES connector that everyone uses to reset the light.
Are you sure about this? I thought they were the same.
Old Mar 2, 2004 | 02:49 PM
Default Re: SRS light reset for the 94 model Accord (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Are you sure about this? I thought they were the same.</TD></TR></TABLE>
Heres the 94 SRS harness. It only has 3 clips on the left (no MES connector).
heres the 95 SRS harness. It has 4 clips on the left with MES connector.
Old Mar 5, 2004 | 09:25 PM
Default Re: SRS light reset for the 94 model Accord (cb7-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R &raquo;</TD></TR><TR><TD CLASS="quote">there is no way to reset it. there is a fault in your srs sytem and it will not go away until it is corrected. unfortuneately only the dealer has the capacity to find the fault and fix it because a special test harness is needed</TD></TR></TABLE>
What if i know what the fault is...how would i fix it?
Old Mar 10, 2004 | 10:01 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
well most problems with srs are electrical shorts some where. if you know where and you can repair the short or open in the circuit then the srs ecu will read it and turn off the light. however if you do not know the problem then I highly advise against trying to find the fault your self because even the slightest electircal current to the srs ecu will cause the air bags to deploy. This is why honda uses a test harness because it is much safer this way
dizney
Jul 23, 2016 02:39 PM
uberEFtuner
Feb 18, 2011 04:20 PM
BlkCivicFromTeamMNR.com
Mar 12, 2008 03:53 PM
old accord
Sep 5, 2005 01:45 PM
'94gsR
Apr 18, 2005 03:07 PM
