Rebuilding D16a6 short block
Can anyone tell me what parts I need?
Crank bearings, rings thats it?
What about putting in oversized pistons? any recommendations, I already have a Z6 head, might as well do more while I have it apart.
thanks
thanks
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
here is what i did.
ACL bearings
D16A1 pistons .20 over (you might not want to do that)
stock rods
that about it
Stan
ACL bearings
stock rods
that about it
Stan
overbore does not increase static compression. with a milled A6 head, A1 pistons and A6 block i got about 11.5:1 CR.
for gaskets, get a rebuild kit from any online sources.
i ended up getting cometic head gasket to knock CR down a tad.
my entire set-up if you want.
A6 head, milled a think a thousand. ISKY valvetrain, Rocket cam. ported and polished, GE cam gear, cometic gasket, A1 pistons swaintech coated, ACL bearings.
Stan
Stan
