DX / Si swaybars
Old Oct 15, 2001 | 02:10 PM
TheShocker's Avatar
Default DX / Si swaybars
Okay this is what I know: Dx has only a front sway bar and the si has front and rear. My question is, is the DX front sway bar the same size as the Si's or are they differet?
-Seth
Old Oct 15, 2001 | 11:04 PM
stockcrix1616's Avatar
Default Re: DX / Si swaybars (miac1)
i wana say the same, although again i could be wrong, i think the difference is the rear sway bar, that gives it the extra edge, and i dont think its too hard to step up to the SI rearend, it will give you the added rearsway bar, disc brakes, and more parts avalible when stepping up suspension.
Old Oct 16, 2001 | 04:21 AM
wronghand's Avatar
I want to add to his question. i have an 88 CRX DX. I have the rear disk brakes and sway bar from a 90 Si. What is involved in adding the sway bar. I know what to do on the brakes. What I don't know is: Is the sway bar a direct bolt on to the DX?
Old Oct 16, 2001 | 10:12 AM
MysteryWagon's Avatar
Default Re: DX / Si swaybars (wronghand)
I would like to know this too, if anyone finds out let us know
Old Oct 16, 2001 | 10:17 AM
in adding the rear sway bar shouldnt be hard if you have the SI rear control arms, there is a place on the control arms to bolt it to, and there are i know 2 L-brackets the bolt the sway bar to the body, you can get the bushing and bracket from the honda place, i had to replace mine on the right rear. hope this helps
Old Oct 16, 2001 | 10:39 AM
wronghand's Avatar
Default Re: DX / Si swaybars (stockcrix1616)
So do the holes in the sway bar brackets line up with the holes that already there? Is it as simple as taking the tow hooks off my DX and mounting the sway bar brackets? I have the lca's and plan on installing new bushings. Thanks again for the help.
Nisif
16
Jan 24, 2006 07:53 PM
crexer
Aug 30, 2004 07:03 PM
jtl
16
Apr 12, 2004 07:43 AM
BIG RICH
Sep 23, 2003 03:20 PM
Spaceballsthelunchbox
Jul 19, 2001 04:37 AM
