Ignition Problems
Old Mar 2, 2004 | 07:53 AM
mongoliandonuts's Avatar
Default Ignition Problems
I just swapped a b16a into 94' del sol si and i had MSD Ignition on the old engine and since th b16 has a internal coil and the ignition i had has a external it wont go so can i use the MSd 8292 distributor from the old SOHC engine should it work or not?
Old Mar 2, 2004 | 07:54 AM
Spade's Avatar
Default Re: Ignition Problems (mongoliandonuts)
No you cannot use the old distributor.
Old Mar 2, 2004 | 07:56 AM
Default Re: Ignition Problems (Spade)
so I have to buy a new MSD distributor or what?
Old Mar 2, 2004 | 08:01 AM
xerox445's Avatar
forget about the msd stuff, just get a stock distro.
Old Mar 2, 2004 | 08:04 AM
Default Re: Ignition Problems (xerox445)
I have the stock ditributor but the other part of the MSD ignition is External coil so how do i hook that up to the Stock distributor?
Old Mar 2, 2004 | 08:22 AM
anyone know how to do it hook the external coil plug into the internal distributor?
Old Mar 3, 2004 | 06:16 AM
xerox445's Avatar
to use the external coil i believe you need the MSD cap with the extra plug on it to plug the coil in.
Xtreme_Cause
18
Jun 22, 2020 08:27 AM
NeMeSiS 171
Feb 19, 2013 09:44 AM
crx(gator)
Dec 4, 2001 09:09 AM
GTEater
Jun 24, 2001 02:58 PM
