DA Integra Axle-Back
Will it work on a CRX? I'm trying to go back to a stock look, but OEM ED axle-backs are hard to find in good shape. I might have found a good deal on one from a Teg which is the same design.
i have a HKS hiper exhaust from a DA on my EF hatch. it had to have one extra hange welded on it, and one of the 45 degree bends had to be opened up a little bit more, but other than that it bolted right up. and since crx and hatch exhausts are almost the same (CRX is a little shorter at the part right after the cat), then the DA exhaust should work fine.
-T
-T
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YumGTR »</TD></TR><TR><TD CLASS="quote">i have a HKS hiper exhaust from a DA on my EF hatch. it had to have one extra hange welded on it, and one of the 45 degree bends had to be opened up a little bit more, but other than that it bolted right up. and since crx and hatch exhausts are almost the same (CRX is a little shorter at the part right after the cat), then the DA exhaust should work fine.
-T</TD></TR></TABLE>
Cool, so it should bolt right up? Also, will it stick out farther than the stock exhaust?
have an exhaust shop put it on for you. it will need to be modified slightly to bolt up. no it will not stick out further in the back, it might need to be shortened up front to fit your car though.
Mike_ef
Dec 16, 2012 07:47 AM
