96 DX Front brakes...
Old Mar 1, 2004 | 09:11 PM
veggiemaster's Avatar
Default 96 DX Front brakes...
Hey, i searched around for this, but all i found was rear brake info. Are the front calipers and rotors on a 96 DX the same as the front calipers and rotors from a 96 EX? i would assume they were, just the rears are different, but i dont know. thanks guys.
Old Mar 1, 2004 | 09:17 PM
Nerologic's Avatar
NO, EX front brakes are always bigger then the DX/LX
Old Mar 1, 2004 | 09:22 PM
Default Re: (Nerologic)
ok, then in that case, is just the rotor diameter bigger? or is the caliper itself physically bigger? and ex brakes bold right up right? yea...
Old Mar 1, 2004 | 09:35 PM
fishnfst's Avatar
I think the overall diameter of the front discs are the same but there is more surface area and the calipers are larger on the ex brakes. I
If you find ex brakes for the same generation as your car they will bolt right up. Get the whole front hub assembly and brakes and they will go right in.
Old Mar 1, 2004 | 10:37 PM
CleanHatch's Avatar
Default Re: (fishnfst)
Ex brakes have different calipers, compare to the Dx brakes. they look totally different if you put them side by side. i'll take some pix 2mororw and let you see. im doing the Dx brake upgrade now.
Old Mar 1, 2004 | 11:18 PM
atermizi's Avatar
Default Re: (CleanHatch)
yeap EX calipers are larger and nicer. You can't even paint the dx calipers coz it's too small.
Old Mar 1, 2004 | 11:29 PM
Ek9Max's Avatar
what if you get the disk and the caliper? will everythign bolt up?
Old Mar 2, 2004 | 12:21 AM
jEssicaKnine's Avatar
Default Re: (Ek9Max)
I think the diameter of the EX rotors are 10.3" I could be wrong.
Old Mar 2, 2004 | 01:23 AM
Bullitt's Avatar
I think the EX have 10.2" and the DX have 9.5"
Old Mar 2, 2004 | 01:28 AM
soundbomber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ek9Max &raquo;</TD></TR><TR><TD CLASS="quote">what if you get the disk and the caliper? will everythign bolt up? </TD></TR></TABLE>
yes
Old Mar 2, 2004 | 07:52 AM
CleanHatch's Avatar
Default Re: (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">
yes</TD></TR></TABLE>
NO!, i tried it, being lazy and didnt want to remove the whole spindle. the HUBs, spindle, barings, are different.
B16KENNY
Suspension & Brakes
Feb 10, 2013 03:29 PM
Redline96LX
37
Feb 20, 2012 02:53 PM
94eh2
Jun 25, 2007 06:29 PM
1clean_ Ej
Mar 7, 2007 07:49 PM
powerslide360
Apr 9, 2005 10:57 AM
