CEL oxygen sensor
Old Mar 1, 2004 | 09:08 PM
jlv55's Avatar
Default CEL oxygen sensor
i just had my car's CEL checked and i came up as two oxygen sensor codes. i have to get my car inspected. is there any way to fix this without replacing oxygen sensors?
Old Mar 2, 2004 | 07:30 AM
Filthy Focker!'s Avatar
Default Re: CEL oxygen sensor (middleman)
That code does not mean the sensor is bad.
Check all wiring to and from the sensor for loose connections, damaged wiring...
Now if you want to test the O2 Sensor, tap into the signal wire of the sensor and check if it is recieving voltage with key turned on of course.
Switch to a low volts or millivolts scale, tap into the sensor's signal wire (typically black) with the positive lead of your meter, and ground the other lead. Get the engine up to normal operating temperature, then hold 2,000 to 3,000 rpm for at least a minute (this step is important with unheated specimens -- oxygen sensors don't produce voltage until they hit 600 deg. F.). Let it come down to idle, and you should see a rapidly changing reading, typically between 100 and 900 mV.
If that is the case, it is good and further exploration is required, if not replace sensor..
good luck
fs
minituner
Mar 26, 2016 04:16 PM
Fatty_1775
Jan 26, 2009 10:00 AM
shifts
Apr 27, 2007 04:14 PM
Lewie
Jun 29, 2004 09:11 AM
99spanishGT
Mar 11, 2004 07:07 AM
