Question about those halo/projector lights...
Old Mar 1, 2004 | 09:07 PM
E-lude78's Avatar
Default Question about those halo/projector lights...
What is the light output of those things? Worse than stock?
Old Mar 1, 2004 | 09:12 PM
kid-honda's Avatar
My buddy has them and they arnt to bad but the back of them stick back into the bay so far it gets in the way of intakes.
Old Mar 2, 2004 | 03:22 AM
E-lude78's Avatar
Default Re: (kid-honda)
I wonder how the lighting would be if HID's were installed.
Old Mar 2, 2004 | 04:43 AM
TiggsCRX's Avatar
I've heard that the projectors suck with hid. Something about the reflectors in the projectors etc not being enough for the hids.
Old Mar 2, 2004 | 08:09 AM
b18CrxSi91's Avatar
71.179.86.205
Default Re: Question about those halo/projector lights... (Mista B-one-seven)
as far as light output mine put out way more light than stock, if you get the halo ones keep you stock headlights incase you have to send them back, one of my halo's didnt work when i got it so....and the lights burn out quick...
Old Mar 2, 2004 | 12:29 PM
vitrox's Avatar
i have a set on my 89, make sure you hold onto the stocks, my halo didn't work when I got em, but I took the housing apart and fixed it with a little help from radio shack. lmk if you have any questions on them, I can probably help you out.
Also, the light output is decent, just make sure you get good head light bulbs, otherwise you'll be wishing you had your stocks back on.
Old Mar 2, 2004 | 06:09 PM
E-lude78's Avatar
Default Re: (TiggsCRX)
has anyone attempted installing HID's into projectors? got pics?
Old Mar 4, 2004 | 11:56 AM
pyro_freak8's Avatar
i've got the halo projectors with H1 bulbs and I find that they put out more light than my stocks....i love them personally and haven't had any problems.... i got mine from k2motors on ebayand they haven't leaked or blown any bulbs or anything , they work great
i'll be doing the hid in a couple weeks, maybe, i'll let you guys know
Old Apr 23, 2004 | 07:09 AM
hawkeye182's Avatar
Default Re: (pyro_freak8)
pyro, are they still working fine?
Old Apr 23, 2004 | 07:59 AM
Keith P's Avatar
Default Re:
HID's won't work well in projectors that were designed to be used with halogen lamps.. the projector lens is not designed for the light pattern.
I've also heard of them melting from the extra heat (most have warnings molded on them)
On 300zx's there is a company that swaps out the porjector lens for one more suited for HID use.
Modified by Keith P at 8:21 PM 4/23/2004
Old Apr 23, 2004 | 08:20 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Re: Re: (Keith P)
HID is a cold burning lamp. i doubt there is any melting occurring. most likely the wires used in conversion are not rated for the voltage and amperage and those heat up and melt. upgrade the wiring and everything should be ok.
anyone still makes non halo projectors?
stan
Junkie
Lighting
Sep 30, 2007 04:52 PM
gimme_h22
Oct 20, 2004 06:51 AM
..::91TEG-G2::..
Jul 8, 2004 08:25 AM
Uneekpinoysk8er
Jun 27, 2004 07:48 PM
pr0jektdc2
Apr 22, 2003 05:30 PM
