ITR Pistons and Rods in LS Block
I going to be doing a LS/VTEC and Im looking at getting some ITR Pistons and Rods, will they fit in the LS Block? And will they work with the stock LS Crank? Please let me know... Thank you... All help would be great...
Ive been reading up, and should I just get ITR pistons because of the stroke and buy some lightened rods for LS block or what??? Will this still work, please tell me your suggestions and what would be the best setup. Thanks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch »</TD></TR><TR><TD CLASS="quote">more detonation for the buck too. i think he needs to do some serious research before even thinking about using CTR's</TD></TR></TABLE>
Word... PCT (CTR) pistons will generate around a 12:1 compression ratio in an LS block. In one of my previous motors, I used PCT pistons, a B18A block with a GS-R P72 head-- that CR was around 12.98:1. I had to use 101octane gas in it in a daily basis. US PR3 or JDM P30 B16 pistons would be a good idea as well.
When I use the CTR pistons, If i was to use them, would I need to get better gas? I use premium or plus right now... And what Im going for is a High Comperession all motor, daily driver? How is that compression? Is that too high for a daily driver??? I want something high, but I can still use Premium if I have to or plus??? as gas? Please let me know. Thank you.
If you're gonna have a high compression motor, use Premium fuel ALWAYS. My stock b16a2 from the factory 10:2 compression, recommends Premium fuel. I would definitely do some more research on LS/VTEC buildups and find a reputable builder before starting..
96tegls
Jun 22, 2004 08:46 PM
