What compression ratio is needed to run CTR,skunk2 STG2 and STG3 cams?
what compression is needed to run ctr cams?
whats the max compression stock ls sleeves can take?
What compression ratio makes these cams run to therir potential?
What rods will do the job for a mild ls/vtec build?, such as eagle etc?
what compression is needed to run stg2 and stg3 skink cams?
Is there a noticable diff in 11.1 and 12.1 motor compression?, and will the cams perform better with 11.1,11.2,12.1,12.5 etc u get the point.
This will be my daily driver and i have 94 oct here in NOVA baby, thats a blessing!!! but 93 is everywhere. My revlimit will be 9k, so lmk what u guys think, thank you..
First off just my opinion
10.5 to 12.5 (basic mods needed i/h/e )
13.0:1 (9cc piston gsr head milled 89 crank)
What compression ratio makes these cams run to their potential?
11.0:1 (depending on header and port intake tb so forth)
eagles are cool
what compression is needed to run stg2 and stg3 skunk cams?
stage 2 12.0:1+ stage 3 13.5:1+ (the cam thing is kinda a trick question because of header intake and head porting. in a n/a setup the whole engine is a team work thing)
Is there a noticeable diff in 11.1 and 12.1 motor compression?, and will the cams perform better with 11.1,11.2,12.1,12.5 etc u get the point.
Yes! Depending on setup intake mani header cams etc.
Also you might want to invest in some injectors 440, Hondata, regulator, clutch, tb, Hondata intake gasket, msd etc. get the works
Good luck with your research and set up
Bubba
Trackmasters
Horizon Motorsportrs
eagles are cool
Bubba
Trackmasters
damn thanx, you answerd all my ****...thanx......any one else...i guess it was too much typing for eveyone else......reall app it..thank you
well I got beat to the punch oh well atleast it's bubba
.............I have leslies engine pic on my comp desktop....( what!!!! I am sucker for fast, nice looking all motor engines
make it breath and feed it fuel and have able to handle the power and you should be fine and running strong for a very long time, but do get it tuned you will be so happy you did
dont skimp on anything. like everything bubba said is what it will take to make this a very nice street set up.
) make it breath and feed it fuel and have able to handle the power and you should be fine and running strong for a very long time, but do get it tuned you will be so happy you did
I'm trying to soak in the information given here. So 11.7:1 with CTR cams "should" be fine. Correct?
fsp31
11
Jun 7, 2005 05:18 AM
bxsi
Apr 2, 2004 05:42 AM
HX_Guy
Aug 22, 2001 02:00 PM
