Question about Radiator Fans
Old Mar 1, 2004 | 07:18 PM
vtec.dc2's Avatar
Default Question about Radiator Fans
my oem passenger fan was replaced with aftermarket, but my driver fan being next to turbine is somewhat melted.. can i just swap the driver side fan for oem passenger fan?
Old Mar 1, 2004 | 10:54 PM
R-1303's Avatar
Default Re: Question about Radiator Fans (vtec.dc2)
by passenger do u mean radiator fan??? and driver side u mean a/c condensor right?
Old Mar 2, 2004 | 04:29 AM
vtec.dc2's Avatar
Default Re: Question about Radiator Fans (R-1303)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-1303 &raquo;</TD></TR><TR><TD CLASS="quote">by passenger do u mean radiator fan??? and driver side u mean a/c condensor right?</TD></TR></TABLE>
yeah.. so can i swap the radiator fan for a/c condencser fan?
Old Mar 2, 2004 | 05:02 AM
PM-Performance's Avatar
a fans a fan . as long as it cools the radiator who cares if its pass side or driver side fan . either do that or get some slimline fans from autozone or something and make em pushers and give yourself alot more room
Old Mar 2, 2004 | 10:49 AM
vtec.dc2's Avatar
Default Re: Question about Radiator Fans (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">who cares if its pass side or driver side fan . either do that or get some slimline fans from autozone or something and make em pushers and give yourself alot more room </TD></TR></TABLE>
well, i don't want to spend money for another fan if i can reuse the passenger side fan.. i just want to verify that it will fit.
Old Mar 2, 2004 | 11:00 AM
like i said a fan is a fan . look for CFM's not weather it was driver side or pass side.
you can make anything fit if you try hard enuff
Old Mar 2, 2004 | 11:05 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">like i said a fan is a fan . look for CFM's not weather it was driver side or pass side.
you can make anything fit if you try hard enuff</TD></TR></TABLE>
i guess you missed a part in my first post. my driver side fan is melted and i just need a quick fix. i removed my passenger side fan for aftermarket for clearance issues.. so its just laying around and it would be free to install, but if its not a direct fit, i'll just get an aftermaket fan.
Old Mar 2, 2004 | 11:15 AM
again ,you can make anything fit if you really try. i forget i think the stock fans were held in by those clips of some sort, its been a while, but you can use those zip tie things to hold it in im sure, like with aftermarket rad fans. only way to know is to try, if its right there, why not try it. Is it just the shroud thats melted? is it really hindering the way the fan spins? if its not i dont see it a dire need really.
Old Mar 2, 2004 | 11:17 AM
MattD@Stoptech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
i guess you missed a part in my first post. my driver side fan is melted and i just need a quick fix. i removed my passenger side fan for aftermarket for clearance issues.. so its just laying around and it would be free to install, but if its not a direct fit, i'll just get an aftermaket fan.</TD></TR></TABLE>
Why don't you try to see if it fits?
Old Mar 3, 2004 | 11:04 PM
R-1303's Avatar
Default Re: Question about Radiator Fans (El Pollo Diablo)
Just make sure it flows just as good with the stock cfm's...but i use a puller for the radiator, and a puller for the a/c condensor.
jdmgeezer
Oct 9, 2007 03:59 PM
schumi
Sep 15, 2007 01:17 PM
teler86
Apr 7, 2006 05:47 AM
smkngsr
Jun 22, 2005 10:46 AM
adnohr
May 31, 2005 10:10 AM
