How to replace a timing belt in a b16a1
also if you search there is one of a del sol. its an sohc but the process is basically the same, you just work with two cams etc. its a really great write up with a lot of pictures to kinda get you started. just search timing belt in the eg civic/del sol forums.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsteezy1290 »</TD></TR><TR><TD CLASS="quote">you got any advice for them </TD></TR></TABLE>
yeah,
Make sure the marks on the cam gears are lined up and the mark on the crank pully is lined up. The instructions should tell you about the marks. This is best done on a lift. You can get to bolts better under the car sometimes.
yeah,
I like to also put a little extra pressure upward on the tensioner when I'm tightening it, the tensioner springs are usually old and don't do their jobs. Make sure what ever article you use that you follow the instructions on how to tension it when you are done. Check and double check when you are done that when you turn the crank counter clockwise by hand that everything still lines up.
techsynthesis
13
Mar 4, 2008 09:19 PM
Jason P
Feb 18, 2008 12:33 PM
custom session
Oct 26, 2007 05:52 AM
loclowd
Jul 23, 2002 11:47 PM
