Need Specs on ZC motors
Old Mar 1, 2004 | 05:11 PM
JapJunkie's Avatar
Default Need Specs on ZC motors
Whats up, im doing a DOHC ZC in one of my rides, and was just wondering if anyone knew the Specs for a DOHC and SOHC ZC motors and if theyre better to have then a USDM LS motor w/ no Vtec???? Thanks in Advance
Old Mar 1, 2004 | 05:43 PM
integ u's Avatar
Default Re: Need Specs on ZC motors (hOnDadiCt)
Dohc non-vtec ZC: black top
130 hp
109 tq
Sohc vtec ZC
120 hp
108 tq
Old Mar 1, 2004 | 05:51 PM
1point5CRX's Avatar
Default Re: Need Specs on ZC motors (integ u)
correct me if im wrong, isnt the sohc zc gears a hair shorter than the dohc?
Old Mar 1, 2004 | 05:58 PM
integ u's Avatar
Default Re: Need Specs on ZC motors (1point5CRX)
No, the dohc ZC is the shortest geared D tranny.
The L3 tranny is the only D series tranny that had optional LSD straight from the factory.
Old Mar 1, 2004 | 10:49 PM
JapJunkie's Avatar
Also does anyone know if they sell aftermarket parts for my DOHC ZC..like cams??? Im looking for headers also
Modified by hOnDadiCt at 11:59 PM 3/1/2004
Old Mar 2, 2004 | 12:27 AM
R6Boy69's Avatar
Any d series header will work... you just gotta port match it to the head cause the ZC exhaust ports are just abit off...
Old Mar 2, 2004 | 09:53 AM
JapJunkie's Avatar
Default Re: Need Specs on ZC motors (crXBoy69)
Is there cam shafts that will work for a DOHC ZC (black top)
Old Mar 2, 2004 | 10:15 AM
integ u's Avatar
nope.
oh I think maybe just maybe, HKS made some camshfts back in the day but they sell for like $950
Check the site.
Old Mar 2, 2004 | 10:19 AM
JapJunkie's Avatar
yO whats port matching and is it expensive?
Old Mar 3, 2004 | 10:28 AM
warchild69's Avatar
port matching is when you take the ZC exhaust gasket and put it up to any D engine exhaust manifold... you will see the extra materal where the gasket lines up with the manifold..... this is the materal that you will have to grind away.. and make smooth.... air porting tool works best.... machine shope in my area will not do it..... dont know why.... very cheap though...... in other area'a like $15.00 if yo have a dremmel then it will take all day..... dude wear a dust mask.... i got one hell of a upper resp. infection from the dust commin off that manifold...
Old Mar 3, 2004 | 10:31 AM
JapJunkie's Avatar
Default Re: Need Specs on ZC motors (warchild69)
Thanks
Old Mar 3, 2004 | 06:24 PM
hitman187's Avatar
I'm getting performance cams from web-cam. webcamshafts.com talk to debbie there. Tell her you just talked to the coolest guy from south bend indiana, and he recommended web-cam.
they have a streetable cam set up and a big motha drag race set up...
go for it.
good luck and happy modding
brett
Old Mar 4, 2004 | 11:27 AM
1point5CRX's Avatar
Default Re: Need Specs on ZC motors (hitman187)
check exospeed.com for cams
bacnoonoi
16
Oct 3, 2008 08:36 AM
Koyoloeor
Aug 9, 2005 04:19 AM
LorenGeist
24
Aug 18, 2004 05:43 AM
newaccordguy2003
Oct 19, 2003 07:48 PM
91ReXSI
Dec 2, 2001 08:06 AM
