any problems with 11.1 comp for a mini-me A6
Old Mar 1, 2004 | 04:25 PM
Renegade's Avatar
Default any problems with 11.1 comp for a mini-me A6
I need to rebuild my block yesterday, looking at a set of SRP pistons that give 11.1. Anyone see any problems with this for a D16A6 - Z6 Mini-me?
thanks
Old Mar 1, 2004 | 04:35 PM
91civicEX's Avatar
Default Re: any problems with 11.1 comp for a mini-me A6 (Renegade)
do the pistons give 11.1 compression on a stock a6 or a stock z6? if its for an a6 it wont be accurate. if you got them for the z6 they should be correct. havent had any experience with compression that high though. thats about the same as p29 pistons right?
Old Mar 1, 2004 | 06:00 PM
Blaze45's Avatar
Brrraaaap!
Default Re: any problems with 11.1 comp for a mini-me A6 (91civicLX)
Make sure that you give it a healthy diet of fuel and atleast 94 octane. If its hot where your at, retartard the timming untill you get it tuned.
Good Luck
Blaze
Old Mar 1, 2004 | 06:07 PM
dpw41285's Avatar
Stock a6 pistons with a z6 head yeild 11something:1 compression. NO need to swap out to Je or Srp unless you are gonna juice it.
Old Mar 1, 2004 | 08:56 PM
Renegade's Avatar
Default Re: (dpw41285)
these are SRP pistons for an A6
http://www.racetep.com/hondasrp.html
I was thinking of running new pistons since I am rebuilding, so I don't really need to?
I thought a6-z6 mini me compression was 10 something?
Is it good enough to reuse the original pistons at 170K miles?
It would save me some money..
thanks
Old Mar 2, 2004 | 12:36 AM
R6Boy69's Avatar
Default Re: (Renegade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade &raquo;</TD></TR><TR><TD CLASS="quote">these are SRP pistons for an A6
thanks
If you reuse the pistons make sure you get some new rings...
turnsignalandy
Aug 11, 2006 11:31 PM
scttydb411
Nov 6, 2004 06:58 AM
Pfieff
Aug 17, 2003 07:43 AM
ImportHatch
Aug 12, 2002 04:49 AM
