OBD 0 To OBD 1 Distributor Pinout Differences (or how does 8 wires go to 9)??
Old Mar 1, 2004 | 03:52 PM
Ruby Civic's Avatar
Default OBD 0 To OBD 1 Distributor Pinout Differences (or how does 8 wires go to 9)??
OK, I am switching obd0 to obd 1 and have dissected the wires to the distributor plug, and the obd0 (PR3) has 8 wires going to the main distrib. plug in but the obd 1 distributor has NINE wires with the extra being a big black 10 guage...
what to do?
Old Mar 1, 2004 | 04:50 PM
CRneXt's Avatar
Default Re: OBD 0 To OBD 1 Distributor Pinout Differences (or how does 8 wires go to 9)?? (Ruby Civic)
I got into this one once a long time ago, and never could make it work out... I think the pickups in the distributor (or was it the CAS?) weren't compatible...
(shrugs) if you make this work, lemme know foreal man. I want to use this FREE distributor I got.
Scott
Old Mar 1, 2004 | 05:44 PM
RedlinedVTEC's Avatar
Sorry can't repin a non obd distributor to work with anything else. You can repin a obd-1 to obd-2 or vice versa, but non obd gets left out in the cold.
Old Mar 1, 2004 | 06:41 PM
Ruby Civic's Avatar
Default Re: OBD 0 To OBD 1 Distributor Pinout Differences (RedlinedVTEC)
uhh, let me put it this way:
i have an obd 1 distributor and an obd0 harness (PR3) and so have 8 wires on the harness side but 9 wires on the distributor side - so do i need the 9th wire hooked up to the distributor because if so don't know where it comes from
got that from Distributor King who ads on these pages
Old Mar 1, 2004 | 06:50 PM
Ruby Civic's Avatar
Default Re: OBD 0 To OBD 1 Distributor Pinout Differences (Ruby Civic)
okay, sorry to alarm peeps and figured out the problem:
i got the harness side plug (obd0) off an accord which is the same EXCEPT for the BIG BLACK WIRE - not on the dizzy so can safely pull
thanks all for your patience
Old Mar 4, 2004 | 03:57 AM
gsrjeff's Avatar
i have a b16a in a 92 cx with an ex harness. I need a obd1 distributor but ur saying about repining obd2 to obd1 is this a posablity 4 me i have a few obd2 dis.
if so do u know the pin outs? thanks
Old Mar 4, 2004 | 08:35 AM
Default Re: OBD 0 To OBD 1 Distributor Pinout Differences (gsrjeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrjeff &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16a in a 92 cx with an ex harness. I need a obd1 distributor but ur saying about repining obd2 to obd1 is this a posablity 4 me i have a few obd2 dis.
if so do u know the pin outs?</TD></TR></TABLE>
Don't have my helms in front of me, but just compare the pinouts from an obd-1 distributor and that of an obd-2 distributor, pretty straight forward.
Old Mar 7, 2004 | 11:22 AM
Ruby Civic's Avatar
i got the electronic swap in but now have a CKP, or CEL4 code
the dizzy is obd1 from Distributor King and the harness is actually from 90 civic Si (obd0)
converting to a plug to mate with the dizzy plug not hard with only two diffs:
obd0 harness/obd1 dizzy:
big white/blue
blue green/yellow green
any ideas as the dizzy is BRAND NEW & untouched??
Old Mar 8, 2004 | 05:08 AM
Ruby Civic's Avatar
i tried reversing these and still get the CEL 4 code, any ideas??
Old Mar 9, 2004 | 09:34 AM
Ruby Civic's Avatar
anybody with Haynes or Acura manual internet source so i can see the wiring on obd 1 dizzy (some you can't read the wire color codes on)
thanks
Old Mar 12, 2004 | 04:26 AM
gsrjeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">
Don't have my helms in front of me, but just compare the pinouts from an obd-1 distributor and that of an obd-2 distributor, pretty straight forward.</TD></TR></TABLE>
the obd 0 & the obd 2 are the same color wire in the same order but the obd 2 has
all wires in one plug obd 0 has 2 plugs. 2 big wires are on on plug the rest on the other dont know what an obd 1 looks like dont have helms only acura shop manual
what is the deal wit obd 0 obd 1 why do i have to change it gets spark but doesnt start hasport said need obd 1 dis. & chiped p28 got p28 need it chiped and need to fig. out dis. if u know any one that rechips ecus? thanks 4 any info. u can give
Old Mar 12, 2004 | 02:05 PM
Ruby Civic's Avatar
yea, kind of strange on my end as it looks to be a good matchup xpt big white to yellow/green on dizzy side and blue/green to blue on dizzy side.....still codes - damn
slowboy90
Jan 27, 2010 09:27 AM
wwcrxww
Sep 28, 2008 09:52 AM
slimer1
Apr 4, 2005 09:06 AM
Ruby Civic
Mar 1, 2004 06:48 PM
kidblackx
Jul 1, 2003 01:23 PM
