how to take out broken studs???
Old Mar 1, 2004 | 03:25 PM
tuan...'s Avatar
Default how to take out broken studs???
well in the whole process of puttin my head back together. i decided to replace my spark plug cover stud i broke awhile back. and my vtec solenoid bolt that i recently over-torqued and snapped. both are flushed. so im not sure exactly how to go about takin it out.. thanks in advance
Old Mar 1, 2004 | 05:16 PM
95 integra's Avatar
Default Re: how to take out broken studs??? (h22a4_dc2)
well there isnt any stress on them, so you should be able to press your finger up against them and turn them out. If this doesnt work, take a drill, put it in reverse and spin it out(worked several times for me). Last resort, go to sears and get the little POS thats made to take them out.
Old Mar 1, 2004 | 05:26 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: how to take out broken studs??? (95 integra)
You said they're flush against the surface? Your best bet might be to go to Sears/Home Depot and get those EZ-out drill bits (I think that's the name). I'm not sure they make them that small, but I'm almost positive they do. It's basically a reverse drill bit made to do work like this.
If there is any of it sticking out, 95Integra has it right. They are just screwed in lightly by hand. If it's tight, and since it's broken anyway, just take some pliers/vice grips, grab on tight and turn em out.
Old Mar 1, 2004 | 08:09 PM
tuan...'s Avatar
alrite i will trythis, thanks
netopia
May 23, 2013 03:57 AM
miguey310
10
Aug 8, 2010 02:26 PM
STROHM
Mar 12, 2009 09:03 PM
red_ek_hatch
Mar 31, 2005 12:21 PM
96BlackHB
Jan 15, 2004 05:30 AM
