abs light stays on.....abs doesnt work...anyone know how to fix this?
when i start my car the abs light is off. but once i start driving it the light turns on....and the abs doesnt work. there is enouph fluid in there...does anyone know whats wrong with it and how i can fix it? thanks in advance.
First thing you need to do is pull the ABS code from the service connector. The service connector is a green plug located under the glove box. Pull out the connector that has the Brown wire and Black wire. Once pulled out, you want to jump the connector by using a paperclip. Turn the car to the ON position and you should see the ABS light flashing.
A long flash is eqaul to 10, while a short flash is equal to 1. Count the flashes and see what ABS code you are throwing.
thanks for the post...i found out that the old owner put the non abs axels in so that was why my abs light was on. i changed them and now it works great...
