will the gsr stock shifters fit in our stock shift linkage?
Old Mar 1, 2004 | 02:50 PM
crashtest Sonny's Avatar
Default will the gsr stock shifters fit in our stock shift linkage?
what topic says.
Old Mar 1, 2004 | 04:37 PM
Default Re: will the gsr stock shifters fit in our stock shift linkage? (crashtest Sonny)
up
Old Mar 1, 2004 | 04:49 PM
CVC9216's Avatar
yes, but not the newer gsr ones, maybe after 96. I can't remember what year, they have wider bushing ends
Old Mar 1, 2004 | 05:00 PM
Default Re: will the gsr stock shifters fit in our stock shift linkage? (CVC9216)
is it only gsr have that nice 'lock-in' feel? like a stiffer shift that feels like its actually in gear? is it the shifter that creates the feel? or the shift linkage?
Old Mar 1, 2004 | 05:16 PM
CVC9216's Avatar
probably the shorter throw. del sol shifters are nice also
Old Mar 1, 2004 | 05:51 PM
Blaze45's Avatar
Brrraaaap!
Ok heres the exprience that I have had. I have a hasport shift linkage. (not really but a knock off) anyways, I had a 99 Si shifter in there, then I realized that its the same as my DX on.... I wasted 20 bucks on it cause my gay SS broke.... So I guess B and D series shifters are somewhat interchageable.
Blaze
Old Mar 1, 2004 | 05:56 PM
Default Re: will the gsr stock shifters fit in our stock shift linkage? (Blaze45)
well the reason why i ask if the b would fit in the d linkage was because i tried to put my SS for the EF into the b16 linkage and it didnt work..well it went in..but the bearing part was smaller..so i had to tighten up the bolt real tight or else the shifter will just move side to side.
Old Mar 1, 2004 | 06:14 PM
dpw41285's Avatar
Alot of del sol owners switch to after market ones and hate it. The del sol shifter is the greates honda put out(minus the s2k and my v6 6spd)
Old Mar 1, 2004 | 06:22 PM
Default Re: (dpw41285)
so the del sol one should fit the d series shifter?
widewhite
Aug 28, 2015 05:14 AM
scoobyjr56
Sep 12, 2008 07:47 AM
SirEm1
12
Apr 27, 2007 09:18 AM
wowowee
Jul 6, 2005 08:39 PM
*Boostwerks*
May 3, 2005 08:32 AM
