not getting fuel??
Old Mar 1, 2004 | 01:28 PM
JdM DiNg DoNg's Avatar
Default not getting fuel??
hey guys...i just put a itr swap in my 94 civic dx and it wont start..tha motor just cranks when i try n start it.. all tha fuses and grounds are good..it has gas... but the cams just spin when i turn tha key... how do i check to see if its getting fuel?? sorry for the shitty post..this cars pissin me off.... thanx..
Old Mar 1, 2004 | 01:50 PM
Default Re: not getting fuel?? (JdM DiNg DoNg)
bada bump
Old Mar 1, 2004 | 02:27 PM
CL9WestCoastin's Avatar
if it cranks, but doens't turn over....the timing is probably off.. check the rotor on the distributor as well as the crannk pully and cam gears all line up correctly.
Old Mar 1, 2004 | 02:49 PM
Turbo E's Avatar
do you hear the pump priming when the ignition is on? a whirring noise, then stops.
Old Mar 1, 2004 | 02:57 PM
b16ahybrid's Avatar
Default Re: (Turbo E 604)
pull your plugs, are they covered in fuel?
Old Mar 2, 2004 | 11:17 AM
Default Re: (b16ahybrid)
yea i hear tha pump priming when tha key is on....and i pulled tha plugs and they were just black on tha ends...not any fuel... i was thinkin it might be tha timing but tha motor was running fine in another car tha same day i put it in mine...is there anyway i could have knocked tha timing off??
Old Mar 2, 2004 | 11:29 AM
b16ahybrid's Avatar
Default Re: (JdM DiNg DoNg)
timing wouldn't cause no fuel.
Do you have good fuel pressure?
Try replacing your plugs, maybe they are fouled.
H22TurboNos
Nov 5, 2007 03:16 AM
accord-h22
Feb 13, 2007 04:45 PM
blaxican05
Sep 29, 2006 08:23 PM
trooper0641
Jul 24, 2005 11:11 PM
dingusjt
Jul 5, 2002 04:10 PM
