GSR Brake Booster/ Master Cylinder
Old Mar 1, 2004 | 01:24 PM
SM 30 Hatch's Avatar
Default GSR Brake Booster/ Master Cylinder
Anyone know if a GSR setup will fit in a 91 civic hatch ?
Old Mar 1, 2004 | 01:39 PM
1's Avatar
Default Re: GSR Brake Booster/ Master Cylinder (integen1)
G2 Integras will swap in. If you are using a 92-93 GS-R master cylinder you must get an adapter for the larger hole in the MC or double flare another fitting on the hard line.
Old Mar 1, 2004 | 01:49 PM
deftones0817's Avatar
Default Re: GSR Brake Booster/ Master Cylinder (1)
it will fit if you want to do it i have a type r brake booster and mc if you want to buy.
Old Mar 1, 2004 | 08:38 PM
Default Re: GSR Brake Booster/ Master Cylinder (deftones0817)
I thought the 98+ type r and gsr came with a 1" MC and the bolt holes were diff. and therefore would not bolt in properly. but if this is not true and it will bolt in. how much are you asking ?
I'm in Northern Va.
MidwestAutoWorks
Suspension & Brakes
Sep 16, 2008 05:49 PM
omiehomie
Feb 15, 2008 04:43 PM
omiehomie
Jul 2, 2005 05:09 AM
JKim0901
May 30, 2004 08:27 PM
