Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Where to buy brake ducting?
Old Mar 1, 2004 | 12:30 PM
SPiFF's Avatar
Default Where to buy brake ducting?
Can't race at CMP w/o ducting. What size should I use for the GSR? Thanks in advance.
Old Mar 1, 2004 | 12:41 PM
.RJ's Avatar
.RJ
Default Re: Where to buy brake ducting? (SPiFF)
Pegasus sells the stuff
Old Mar 1, 2004 | 12:43 PM
travis's Avatar
I have ordered all of my hose from http://www.racerpartswholesale.com and I have been happy with their selection. I currently run 3" from the bumper ducts but I have adapted it down to 2.5" where it enters the wheel since I had significant rubbing with the 3" hose. The cheaper stuff comes in lengths of 10' and the more expensive stuff comes in lengths of 11'. I found 10' to be more than enough.
A good temp idea is 3" dryer ducting at less than $10 for a 6 or 8' length. It won't last long, but it's cheap enough to replace every day if you need to. The downside is that it's much harder to get really close to the center of the rotor and most people just end up pointing it at their caliper from the radius rod. It also tears very easily.
Old Mar 1, 2004 | 03:55 PM
phat-S's Avatar
BSR products up here in CLT has all sizes. We use the 3" variety.
Old Mar 1, 2004 | 05:08 PM
cbstd's Avatar
A cheaper alternative is to buy some shop-vac hose from Home Depot and use the cheap nossle attachments for ducts.
Scott
Old Mar 1, 2004 | 05:10 PM
Willard's Avatar
http://www.musclemotorparts.com/
used = good.
Old Mar 1, 2004 | 05:17 PM
krshultz's Avatar
I like the 3" expensive silicon stuff. It's tough and big. Got mine from Pegasus.
Old Mar 1, 2004 | 07:46 PM
tnord's Avatar
Default Re: Where to buy brake ducting? (krshultz)
Pegasus
FOBrudy
Welding / Fabrication
17
Mar 30, 2013 11:16 PM
vtec8200
Dec 7, 2011 01:04 PM
AnAccordIsForever
Nov 10, 2008 07:20 PM
Jared
21
Jan 8, 2008 07:40 AM
vr6chris
Jan 18, 2005 08:39 PM
