i need some help
Old Mar 1, 2004 | 09:12 AM
jffcivic's Avatar
Default i need some help
my f**king drain plug has striped the threads out of my oil pan and i can't get it out someone please tell me a way without pulling the pan
Old Mar 1, 2004 | 09:27 AM
Filthy Focker!'s Avatar
Default Re: i need some help (jffcivic)
Pull it out simply... either Pry it out, use vise grips, etc...
And fix it fix a self threading oversize drain plug...
Next time don't overtighten.... Just snug it up..
fs
Old Mar 1, 2004 | 09:30 AM
95civicracer's Avatar
yank that bitch out and then use a tap and die kit.
Old Mar 1, 2004 | 09:31 AM
Default Re: (95civicracer)
Don't go tapping in there.. Buy a oversized self tapping drain plug. They are meant for that...
fs
Old Mar 1, 2004 | 09:56 AM
jffcivic's Avatar
Default Re: (filthy_shovel)
can't pry the plug out can't get under it an i just bought the car the previous owner
already used an oversized plug they messed it up
Old Mar 1, 2004 | 09:58 AM
moondoggy's Avatar
just get into a shop and re-thread the pan.......it cost more now but saves you the hassle later
Old Mar 1, 2004 | 10:06 AM
Default Re: (jffcivic)
Damn....
Ok 1 choice here... buy a new pan...
If you bring it to a garage, they will probably end up replace the pan, so why ot do it yourself...
fs
Old Mar 1, 2004 | 10:08 AM
moondoggy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by filthy_shovel &raquo;</TD></TR><TR><TD CLASS="quote">If you bring it to a garage, they will probably end up replace the pan, so why ot do it yourself...
you can just get them to re-thread........unless your pan is all f*cked up
Old Mar 1, 2004 | 10:49 AM
Default Re: (moondoggy)
Depends how much material is left... If you have an oversized plug, it is quite reasonable to think that not enough material is left to re-thread...
fs
Old Mar 1, 2004 | 06:01 PM
jffcivic's Avatar
thanks but the engine is only going to be in for a few more monthe i just need to get the old one out
thanks again for your help
Old Mar 1, 2004 | 06:04 PM
2+2Door's Avatar
pry with a flat head and crank at it with vice grip, or you can just drill it out.......................
Old Mar 1, 2004 | 06:29 PM
T.J.'s Avatar
I had the same problem about 2 years ago , and had to get mine out that night. Since it was 11 at night nothing was realy open . So i went to my 24 hour Wallmart and foudn a socket that was like gator wrench or something. They claim it could remove and stipped nut. So i bought took it home tried it out, and it worked. Not saying it was a quality tool but it saved my but that night.
Old Mar 1, 2004 | 06:34 PM
honda_S's Avatar
hahaaha i was just about to recomend a "gator grip" too man that **** saved my *** all the time its almost as usfull as duct tape
Old Mar 2, 2004 | 04:28 AM
Default Re: (8y61d)
Yeah gator grip is good, only if you stripped the head of the nut, not the threads....
Old Mar 3, 2004 | 06:23 PM
jffcivic's Avatar
thanks for the help
GSE980
Jun 27, 2016 09:16 PM
98bwahhek
12
Feb 7, 2013 09:04 AM
mish__
Nov 16, 2010 07:52 PM
Enzo757
12
Jun 16, 2007 12:31 PM
Ls InTeGrA RaCeR
Jan 10, 2006 12:21 PM
