Koni yellow adjustable perch.
Old Mar 1, 2004 | 08:50 AM
busakiller's Avatar
Default Koni yellow adjustable perch.
I got my Koni Yellow's and in the instruction it show's the shock in a vice for some kind of adjustability... Can someone explain the reason for this... I thought you just adjust them from the top with the plastic ****... Is the 3rd perch setting like as if you bought non-adjustable shock??
Old Mar 1, 2004 | 11:28 AM
R.S.'s Avatar
Default Re: Koni yellow adjustable perch. (busakiller)
the perches are to raise and lower the ride hight
the pic of the shocks in the vice is b/c for some cars the Koni yellows aren't externally adjustable (by the white **** thing)
Old Mar 1, 2004 | 11:32 AM
busakiller's Avatar
Default Re: Koni yellow adjustable perch. (R-Spec)
cool... I have a 99 si so I guess I can adjust mine from the outside....
R.S.'s Avatar
the what are you asking?
Old Mar 1, 2004 | 11:37 AM
busakiller's Avatar
There are 5 perch setting... If I would have bought kyb agx shocks you can't move the perch... I'm wondering which perch setting would be consider a stock perch setting...
Old Mar 1, 2004 | 12:11 PM
busakiller's Avatar
Default Re: (superpirate25)
cool... I didn't know if the top one was the stock setting or not.... thank you...
Old Mar 3, 2004 | 04:02 AM
busakiller's Avatar
Default Re: (busakiller)
Anyone have the perch on the lowest settings??? Will it make the ride harsh??? I'll have ITR springs installed... I was thinking second from the bottom perch for the front and bottom perch for the rear..
ciiivic89
Suspension & Brakes
17
Feb 20, 2009 01:49 PM
yaoming315
May 7, 2007 08:12 PM
Undercover_Skank
Feb 21, 2004 05:57 PM
taytay333
Mar 26, 2002 03:54 PM
Rob Dizzle
Feb 27, 2002 07:58 PM
